im loosing a lot of oil!!!!
Old Sep 21, 2009 | 07:04 AM
granny racer's Avatar
Default im loosing a lot of oil!!!!
i jacked up my car and took a look under neath. and oil is leaking and looks like it sprayed allllllll of the back of my engine. i looked and looked, i cant figure out where its coming from.. it looked like it was leaking from the oil filter, but its on good, and i dont think that would cause the oild to be everywhere, but with pressure i dont know. any ideas?
i suspect
1. oil pan gasket" i coulda hit something against it from the road"
2. my oil filter might not have that rubber ring on it.
3. my o ring on my distributor is leaking a little bit, too but i dont think thats the problem
4. and finally my head gasket
which one of these could cause oil to be everywhere on the back of my engine?
im hoping there isnt a crack
thanks in advance
Old Sep 21, 2009 | 09:54 AM
Default Re: im loosing a lot of oil!!!!
no ideas?
Old Sep 21, 2009 | 10:07 AM
djkurious's Avatar
Make, Model, and Year would be a good start...
Pictures, would be great...
Also, have you recently done a valve cover gasket replacement?
Old Sep 21, 2009 | 10:11 AM
95 accord dx f22b2
and yes. i did replace it a week ago
but the major splattering was there befor that.
ive had the car for a month
Old Sep 21, 2009 | 10:13 AM
gianinline's Avatar
A leak from the distributor "o" ring can reach all the way the pan and tranny. If you have vtec engine, the solenoid's gasket can leak behind the motor too.
There are a few possibilities... rear main seal (by flywheel/clutch), crank seal or any of the other seals behind the timing belt cover. Oil pan can also be listed, but a leak from there wouldn't go upwards on the back of the engine.
Clean and degrease the motor. Buy a can of degreaser for about $5 or 6 dollars, protect the distributor and alternator, spray the engine... lift the car and spray some from under the car, reaching the back of the engine and tranny. Let it soak for 10~15 minutes, scrub it a little if you can, rinse with water (warm/hot water is best and helps dissolve oil). Allow it to dry and now you have a fresh start to see where the leak is coming from.
Old Sep 21, 2009 | 10:30 AM
ok. ill definitely get the degreaser, rags didnt work that good -.- haha
i know the o ring is leakin for sure, should i replace that like today?
Old Sep 21, 2009 | 12:33 PM
deserthonda's Avatar
chk the oil pressure sending unit......also the oil filter cooler housing o-ring if it has one
you should clean it up and see if leak is coming above oil pan if it is ,, it is not the oil pan gasket leaking..
Old Sep 21, 2009 | 12:47 PM
tamadrummer1120's Avatar
Gian is right. if anyone ever has a problem with finding an oil leak, the best bet is to wipe down the entire surface area around the suspected places really well and all the oil that is leaking and turn the car on and look for any immediate oil leakage, then take the car for a small drive, like down the neighborhood and back. and see if the oil has come back, and where from. This can help narrow the problems down.
Old Sep 21, 2009 | 01:13 PM
if it can really reach to the back, then im gonna wipe that down first, brb
Old Sep 21, 2009 | 07:10 PM
gianinline's Avatar
Yes, but you do that before you replace anything, and make sure you do a good job for yourself, even if the 15 minutes job turns into a 2 hours clean up where you spray the engine 10 times with degreaser, it is important to clean it well... so you can go to the right place when you see oil again.
It is a good practice of diagnosing a problem by doing maintenance, it is NOT a waste of money, but while searching for a problem, you're taking care of things that are part of a list of things that have to be looked on every now and then.
So, good luck finding it!!
Old Sep 22, 2009 | 02:34 AM
dafang's Avatar
I had similar problem, after replacing all gaskets, I found it was the oil pressure sending unit, which was a simple and cheap fix.
Old Sep 22, 2009 | 07:53 AM
all the gaskets.the head gasket too?
i got the degreeser. i wont have time to search today, so im just keeping oil in it.
im also thinking, that when my uncle put on my new filter, he didnt take off the old ones rubber ring, oil could be shooting out cause theres two ruber rings letting pressure escape n stuff. ill check it out though
Old Sep 22, 2009 | 08:18 AM
dafang's Avatar
Not the head gasket, just the oil pan pan gasket and valve cover gasket (which were both as hard as a rock)
Old Sep 22, 2009 | 08:23 AM
hmmm, i just replaced the valve cover gasket
how much $$$ was that oil pan gasket?
i got 5$ in my pocket till friday
Old Sep 22, 2009 | 08:35 AM
dafang's Avatar
Spend your $5 on replacing the oil pressure sending unit. This is more likely leaking than your oils pan gasket. (Also much easier to replace)
Old Sep 22, 2009 | 08:38 AM
cool, do i have to take off the head to put that on O.O! ?
Old Sep 22, 2009 | 09:11 AM
nus_dogg's Avatar
The F22B2 don't have the oil cooler like the H22s; unless, I'm wrong. I've had the F22B1 before my H and I've never seen a oil cooler on my B1.
Old Sep 22, 2009 | 11:23 AM
dude, i think your totally right, im @ work with no jack, its hard to see it, but i shined a light in between the IM and i seen a some drips!! they dropped right on top of the oil filter, how much was the oil pressure sending unit???
Old Sep 22, 2009 | 11:29 AM
dafang's Avatar
Sender unit is less than $10 at Autozone.
Old Sep 22, 2009 | 11:36 AM
ahhhwwww
well im halfway there
was you able to put in the new one from under the car?
also.
do i need anything else?
Old Sep 22, 2009 | 12:28 PM
i hope thats the problem, it does this everyday now , i go through more oil than gas, its went through almost all the oil in two weeks
Old Sep 22, 2009 | 01:03 PM
dafang's Avatar
I installed from under car, just drive up on about 3 - 2x4's. There will be a rubber boot on plug. I had to break it off as it had dried rock hard. You will need to remove oil filter, but there is no need to drain oil.
Old Sep 22, 2009 | 01:08 PM
do i need the boot too?
and thanks for all your input
Old Sep 22, 2009 | 01:15 PM
dafang's Avatar
The boot is just to keep the dust and dirt off, it is not needed. You cannot buy it anyway.
Old Sep 22, 2009 | 01:17 PM
cool, thanks again
i shal replace it this weekend!!!!!
unless it has to be ordered
JDMob
Jan 26, 2020 11:17 AM
mrspeedy69
14
Feb 5, 2012 11:48 AM
davey5300
May 7, 2010 06:01 PM
B16CivicEX
May 30, 2006 03:15 PM
anirtak
Mar 16, 2004 06:16 PM
