Da problem
Old May 8, 2006 | 10:13 PM
JDMob's Avatar
Default Da problem
My 91 da is leaking oil all over the exhaust system....idk where its coming from when I drive slow its fine, But when I floor it. It starts to smoke from the oil on the exhaust. I really don't see oil coming from the head but I know its coming from the back of the motor some where. What could this be I need to get it fixed asap. thanks
Old May 9, 2006 | 08:05 AM
I Have an STD's Avatar
wrenchin'
Default Re: Da problem (JDMob)
probably an oil pan gasket. get a new one and replace it, you'll be just fine. i think ive replaced the pan gasket in each one of my DAs and and im on my 3rd gasket on my current DA
Old May 9, 2006 | 11:04 AM
JDMob's Avatar
Default Re: Da problem (I Have an STD)
Thanks that's what I'm guessing it is to. But there's a little oil above the oil pan. So idk if its just that, or if the oil Is every where because of the pressure and the gasket being gone so the oil flying all over ****.
Old May 9, 2006 | 11:49 AM
Rice-aronie's Avatar
did you change your oil recently then this started to happen? If so I suggest you check your filter and make sure your old oil filter gasket is not stuck on the block which means u have 2 gaskets on there. Also check if the oil is leaking from the oil sensor plug area.
It seems to be dripping from somewhere from the top. I doubt its the oil pan gasket unless you are pouring oil from there.
Old May 9, 2006 | 12:05 PM
g2forlife's Avatar
you might have not tighted your oil filter check that and see if thats your problem....
Old May 9, 2006 | 12:38 PM
JDMob's Avatar
Ill check it all out. I just got the car from (JUN-tech) so now I wonder if he knows his ****. I'm going to get under the hood soon in the next couple of days and ill post about my out come. Thanks
Old Jun 26, 2006 | 09:19 PM
JDMob's Avatar
Default Re: (JDMob)
Last week was a good week took off the oil pan gasket changed the oil...now runing like a champ. Took me forever to get to it but thanks guys for your post help me out big time i love my LS
Old Jan 26, 2020 | 11:17 AM
joey Pallotta's Avatar
I just had the same ****, it was the oil filter housing leaking , (not the filter itself) im fixinf now i will repost. good luck
mwstrick
Jul 24, 2007 09:19 PM
Kapetan
Oct 19, 2006 08:35 AM
Teglessb18
Oct 21, 2005 03:06 PM
Mattyg2
Aug 28, 2004 04:50 PM
jwiedmayer
Nov 30, 2001 07:02 AM
