How long to take out my engine?
Old Sep 20, 2009 | 08:49 AM
jhendry's Avatar
Default How long to take out my engine?
my engine bay is in need of some super cleaning and i''m just wondering how long it would take to drop my motor to get some cleaning and painting done.
1994 Honda Civic Si HB
D16ZC
Old Sep 20, 2009 | 08:53 AM
vtechjunkie's Avatar
Default Re: How long to take out my engine?
20 minutes if you know what you are doing.
Old Sep 20, 2009 | 09:13 AM
thumper64's Avatar
Plan for a couple hours at least.
Old Sep 20, 2009 | 09:16 AM
jhendry's Avatar
k well i'm still learning honda so kind a know what needs to happen just not sure on the order. does any one know of a FAQ or how to on this? or some one give me a quick order on what to disconnect first?
Old Sep 20, 2009 | 09:20 AM
Do all the plugs first, then undo all the hoses. Pull the axels, and exhaust manifold, unbolt the mounts and pull it out. Not to start an sh*tstorm, but it shouldn't take you a couple of hours. Not even on your first time. Just make sure that you make a good mental note of where everything went. Or just label it. Then it may take you a couple of hours. GL
Old Sep 20, 2009 | 09:25 AM
thumper64's Avatar
If you're pulling the engine out, and aren't swapping, there's not much to mix up. I labeled EVERYTHING when I pulled my engine out of my 4 door.
When you remove your mounts, undo the rear mount first, then the front torque mounts, and after hooking up the hoist, then remove the two upper mounts. It WILL hold the engine just fine.
Old Sep 20, 2009 | 10:22 AM
jhendry's Avatar
hey thanks guys i really want to paint my engine bay but do a decent job and the engines gotta come out and i'm considering a swap around spring or summer next year so it's be a good learning experience. and i think i'll do a wire tuck while i'm at it. should be lots of fun. i think i'll make a little blog not a build thread. it'll be just a page about me trying to make this car look good.
considering a b16a obd1 maybe 2
or a h22a obd2 swap
thanks for the help do you guys know of any place that would rent me a engine lift?
Old Sep 20, 2009 | 10:54 AM
Pabs626's Avatar
get a pressure washer and some awesome dont pull out the engine unless ur swaping it its a waste of time
chadalac1712
Oct 30, 2007 05:45 AM
meno19
14
Aug 2, 2006 03:03 AM
Lost_clearance
May 29, 2006 06:41 PM
bmiller17
Mar 18, 2006 09:27 AM
turbotime
16
Mar 10, 2004 05:12 AM
