Removing Engine From Top or Bottom? suggestions
just wondering do most of you honda guys remove the engine with the K frame or just lift it from up top
Re: Removing Engine From Top or Bottom? suggestions (Lost_clearance)
my brothers, friends, and I have done a dozen+ swaps, typically we undo all the engine mounts bolts and put the engine lift chain on the crossmember and lift the car up, put a piece of old carpet under the motor first and you should be able to pull the whole motor out of the front of the car while the frame is lifted up.
crzy1208
01-23-2013 03:03 PM
