turbo b18c.. turbo camshafts?
Old Sep 19, 2009 | 02:58 AM
turbodailydan's Avatar
Default turbo b18c.. turbo camshafts?
hi guys
i have a b18c fully forged with ITR head and ITR camshafts. running a 57trim which is pushing 450bhp @ fly on 1.2bar..
just wondering would there be any benefit changing to some turbo specific camshafts rather than using the ITR ones im currently using..?
thanks - dan
Old Sep 19, 2009 | 04:40 AM
civic-r11's Avatar
Default Re: turbo b18c.. turbo camshafts?
Look up on here and u will find your answer, from your question u did not look up anything.. This has been answer millions of time
Old Sep 19, 2009 | 04:41 AM
just did a search appears itr cams are the way to go thanks
Old Sep 19, 2009 | 04:59 AM
civic-r11's Avatar
If u want more power u can change your cams, but turbo cams are crap to me. Skunk 2 pro 1's are my choice for a vtec b series head trying to make big power
Old Sep 19, 2009 | 06:09 AM
redflaredcrx90's Avatar
used skunk 2 tunner stage on pro1 are a lil harder on the valve train and the tunnner stg1 you can use it with your itr stock set up
Old Sep 19, 2009 | 06:34 AM
96 GSR-T's Avatar
Pro-1's are too much Cam for a .57 trim, Tuner1's will pick up 20-30whp over ITR's and they will be compatible with your setup if you choose to switch cams.
Old Sep 19, 2009 | 01:40 PM
DA TeG 90's Avatar
Blox Type B cams. Cheaper, and work just as good as the tuner 1's. Basicly the SAME specs.
Old Sep 19, 2009 | 03:41 PM
trickeng's Avatar
You can also through a ctr intake cam in. That will give you a little. But only if you can find one cheap. If not, then the type B or tuner 1's.
VTEC-Brazil
Aug 22, 2006 05:33 PM
alpha_1
Sep 16, 2004 04:25 PM
vtec65
Jul 29, 2002 07:54 PM
FOrSfEd
May 16, 2002 05:47 AM
Kamin
Oct 12, 2001 06:08 PM
