turbo b18c.. turbo camshafts?
hi guys
i have a b18c fully forged with ITR head and ITR camshafts. running a 57trim which is pushing 450bhp @ fly on 1.2bar..
just wondering would there be any benefit changing to some turbo specific camshafts rather than using the ITR ones im currently using..?
thanks - dan
thanks - dan
Re: turbo b18c.. turbo camshafts?
Look up on here and u will find your answer, from your question u did not look up anything.. This has been answer millions of time
If u want more power u can change your cams, but turbo cams are crap to me. Skunk 2 pro 1's are my choice for a vtec b series head trying to make big power
used skunk 2 tunner stage on pro1 are a lil harder on the valve train and the tunnner stg1 you can use it with your itr stock set up
Pro-1's are too much Cam for a .57 trim, Tuner1's will pick up 20-30whp over ITR's and they will be compatible with your setup if you choose to switch cams.
You can also through a ctr intake cam in. That will give you a little. But only if you can find one cheap. If not, then the type B or tuner 1's.
alpha_1
09-16-2004 04:25 PM
