d16y8 Turbo or b16a2
Old Sep 5, 2009 | 09:13 PM
XanderusMaximus's Avatar
Default d16y8 Turbo or b16a2
So i have a 1997 Civic ex, d16y8 SOHC VTEC.
I can't decide between a b16a2 or to turbo the stock engine.
At the moment i am leaning toward b16 but i want some professional opinons.
One of my worries about d16 turbo is the stock engine has 135k miles on it and im wondering if it will be able to handle 8 psi without me have to do anything else to it.
Also, in the long run im thinking b16 because i can do way more stuff to a b16.
So i would like to hear what you guys have to say about it.
Old Sep 5, 2009 | 09:17 PM
worlds-slowest-EG's Avatar
Default Re: d16y8 Turbo or b16a2
what is your hp goal? the d series crank is good to about 300hp and the rods are ok to almost 180hp so that might be a limiting factor. although you can get forged rods and 300hp is a bit overkill for a fwd street car.
Old Sep 5, 2009 | 09:20 PM
jyacoba2009's Avatar
if your going for the long-run.. b16 ftw
but if you want quick power and thats it, d16 ftw.
Old Sep 5, 2009 | 11:35 PM
boxeocampeon's Avatar
turbo the d16 and then rebuild the engine thats wut i would do its gonna be way more expensive to get a b16 in there then it will be to build your d16 but it does depend on what your main goals are
Old Sep 5, 2009 | 11:40 PM
Ruben19's Avatar
go turbo y8.
b16 N/A sucks
he said in the long run the b16 would be a better suit.. so i can assume this won't be a just a 6-month or 1-year project.. probably build it bigger and better as years pass
Old Sep 5, 2009 | 11:51 PM
MHDesigns's Avatar
that y8 can't handle **** though. The y8 is known for doing one thing really well, bending rods(been through several of them myself). I would go with ls/gsr tranny. **** the b16...no torque. Spend the same money on a better piece of clay. just my .02
Old Sep 6, 2009 | 12:00 AM
ccarey's Avatar
i cant believe I actually agree with you. If you don't mind I do have a question for you because I have noticed you ls/vtec symbol. Is that what you run?
MHDesigns's Avatar
Indeed.
Old Sep 6, 2009 | 12:02 AM
ccarey's Avatar
i am sending you a pm
Old Sep 6, 2009 | 09:50 AM
ANNiHiLATORS's Avatar
i would go with the b16
Old Sep 6, 2009 | 10:44 AM
ltrkstr2k's Avatar
go with the b16. it will set the car up for way more options in the future. ie head block swaps more tranny options
Old Sep 6, 2009 | 11:01 AM
tehteg's Avatar
If you're really set on a swap I'd go with either an ls w/ gsr trans (I'm getting ready to do this exact swap on my 97 hatch), or if you want a b series vtec I'd go with a gsr swap.
Old Sep 6, 2009 | 11:09 AM
Bisimoto.com's Avatar
From: Ontario, CA U.S.A. *Dyno Tuning *Performance Parts *Engine Design *Custom Parts
Xanderus,
We would highly advise you to "Begin with the end in mind."
There are key components to embarking in such a feat:
For example: Your budget, your timelines, your end goal/usage for the vehicle... etc.
It is also a great idea to research some of the other builds/swaps that were already done, and try to learn from his/her experience.
Hope that helps!
p.s. pm sent
tyb
18
Aug 6, 2013 04:19 PM
Northern Civic
Mar 16, 2012 01:47 PM
leroyb
14
Jul 31, 2006 10:33 PM
jamesr
Feb 16, 2004 10:19 PM
d16y8EL
Jan 2, 2004 10:17 PM
