Missing/Stumbling issue
Old Sep 5, 2009 | 12:24 PM
NACvicSi's Avatar
Default Missing/Stumbling issue
Well about two weeks ago I was driving (99 Civic Si) and all of a sudden the car quit and wouldn't start. I got out started checking the usual and couldn't find anything wrong right off the bat. About 5 min later it cranked right up and ran fine. I thought it was sort of odd, but seemed to work fine.
Now about 5 days ago I was driving home from work (1hr 15min drive) and close to home it was like hitting a brick wall. RPM's started dropping and car wasn't going anywhere. Took it out of gear (didn't quit) and waited a couple seconds and put it back in gear and then went on like no ones business.
Now two days ago I was on my way to work and it did it again. Same thing took it out of gear and waited a few seconds and went right along. I was thinking clutch slipping at first for some reason as it seems it only happens when the rpms are higher (around 4k) each time.
The next day I decide if it does it again I'm going to just keep on it and see what happens. It did it again that morning (yesterday) and when I just kept it in gear and gas pressed the car had a stuttering feeling and then died. Put it in gear after a couple of sec (I was doing about 65) and let out on the clutch and it started up and drove on to work.
I know think it maybe an ignition issue. I checked the wires and they look good. I just bought the car about 2 months ago so no idea when they were replaced but look pretty new. The dizzy cap looked fairly new also with just a little white and gray corrosion on the points (which I sanded off clean and smooth). The dizzy rotor had some white residue also with a little black spot that I sanded off and cleaned, but it looked semi decent also.
It seems to only happen after I have been driving the car for awhile, so I might have to wait till Mon to see if that solved anything. Any other ideas you guys can think of?
doubleoazn03
Nov 17, 2014 07:54 AM
dc5tegk20
Transmission & Drivetrain
Jan 27, 2009 10:39 AM
SHluder
Jan 1, 2006 01:11 PM
Veritas-Aequitas
Jun 8, 2005 04:20 PM
SiRkid
Aug 23, 2003 11:04 PM
