starts and stallsi
have a hatch 94 and I don't know what's wrong but my car does this from time to time. When I start the car it starts and then stalls but I can catch it before it stalls and hit the gas pedal an it will stay started up. Or if I let it stall I can pump the pedal and turn the key and it starts up. It does it with no schedule. Sometimes with a full tank sometimes with low fuel. Sometimes in the cold sometimes in the heat. I thought it was something by the way my car is parked in the driveway tilted down so I backed in and it does it too but it does it in flat parking lots what's wrong?
no cel's. I know everything in the fuel system is still original. Could the fuel filter need to be replaced? And what about the injecters? I also took into consideration the fuel pump. I just need some advice or some personal experience before spending any monies.
My 96 civic is doing the same thing, I cleaned the IACV ,checked my distributor and its internals looked fine. I'm hoping its just the fuel pump also, and nothing major, although the car sometimes idles at 100rpms until I give it gas lol.
BUMP For Answers
BUMP For Answers
I apologize to the thread starter for thread jacking LoL
Again, not sure why you'd focus on the fuel pump. Have you inspected/test the plugs, wires, cap, and rotor and checked the ignition timing? Is the CEL on?
I believed it was the Fuel pump because the car would bog at WOT.
Yes I have checked the distributor and I've noticed that the spark seemed really weak, I've changed the plugs (they were literally .70).
I'm currently Trouble shooting everything from the Fuel Pump to the Distributor in hope to solve this problem.
Yes The CEL is on, Plan on jumping it tommorow to read the code.
yeah nice thread jacking but my problem is not cranking or starting up. It starts up and cranks awesome. It starts fine but it stalls once it starts I meant the valves in the throttle body. I'm just afraid that this coming winter it will be worse. I never touched the pcv valve. And I know it's only like 3$ so I'm going to try that tommorow. I really just need some advice on the stalling. Just don't want it to get worse.
silverlude80
Aug 8, 2008 08:46 AM
