car not getting gas
Old Nov 11, 2005 | 10:49 AM
IAteg's Avatar
Default car not getting gas
I was driving and my car just died went to start it nothin. Started checking stuff took off a fuel line and its not getting gas. You can still hear the fuel pump turn on tho. What do you think is wrong with it, could it be the fuel filter is clogged or the fuel pumps fucked up. A couple minutes before this all happen i hit a bump and the car kinda slammed on the ground so the gas tank coulda got pushed up and broke the fuel pump or something but wanted your input before i go spending money on a new fuel pump or w/e.
Old Nov 11, 2005 | 12:31 PM
BlackDAy's Avatar
Default Re: car not getting gas (IAteg)
if there's no fuel in the fuel line, it's probably ur pump.
Old Nov 11, 2005 | 12:34 PM
blakezilla06's Avatar
Default Re: car not getting gas (BlackDAy)
A weak fuel pump or one that can't generate enough pressure can upset the calibration of your fuel system. This may cause the engine to run lean or starve for fuel under load, causing symptoms such as hard starting (hot or cold), poor idle quality, hesitation or stumbling when accelerating and a loss of high-speed power.
It's definately your fuel pump!
jastonian106
Feb 28, 2015 09:03 PM
hondaapi
May 13, 2010 11:39 PM
Maple50175
Apr 11, 2009 07:26 AM
pr3lude1992
Feb 18, 2009 06:30 PM
Hispeed
Jul 13, 2001 09:16 AM
