Transmission & Drivetrain Gearboxes, Differentials, Clutches
Searching for a LSD.
Old Aug 31, 2009 | 07:36 PM
425_Booster's Avatar
Default Searching for a LSD.
Well, to start off and make a long story short. I bought a tranny from a guy about 1.5 years ago for my project. When I first bought it and checked it out, it seemed fine. Unfortunetly, at the time I didnt know to much, was throwing to much money around, and now paying a price for it. Project has been off and on for 2 years. Fast forward to last Friday night. We put my shift linkage in and it wouldnt go into gear. Saturday we find out the inside is completely messed up. (i know. i know. it took way to long....anyways)
Now, Im in search of a new LSD and probably some gears. Mainly after LSD right now. It is a high HP car and dont want to skimp on it. I figure while its apart, I might as well replace the stuff with good stuff. Im thinking Carbonetic Carbon LSD right now. Any other suggestions? Im open right now.
Old Sep 1, 2009 | 08:54 AM
Aquafina's Avatar
Default Re: Searching for a LSD.
If its high power and for drag, you don't want a clutch type diff. You want a helical type diff. So MFactory or Quaife.
As for gears, either MFactory PRO 1/3/4 and PRO 4.05 FD or PRO 1-4 and PRO 4.05 FD.
Old Sep 2, 2009 | 07:40 PM
whats the difference between helical and carbon? why is it better?
Old Sep 2, 2009 | 07:49 PM
whats the difference between their FD and Pro FD. Pro FD is $200 more. is that gear set $2000? making sure im looking at the right one.
Old Sep 3, 2009 | 10:38 AM
Aquafina's Avatar
Helical uses gears to function, clutch type uses clutch plates. Helical will last longer (never needs to be rebuilt) and clutch type's are likely to break the clutch discs when used for drag racing.
Difference is the material used, PRO gears are much stronger.
Old Sep 21, 2009 | 02:39 PM
99kleansi's Avatar
How about the WacTrac diff? You have any experience using that one? I have heard nothing but good thing so I bought one too. Seems great for high HP and no maintenance also has Limited LIfetime Warranty.
Old Sep 21, 2009 | 06:00 PM
Aquafina's Avatar
I think its just the same as any other good helical LSD but with some bling carbon in it. After talking to Autotech at SEMA last year, they couldn't explain how it works differently than a regular helical LSD and I couldn't see how it does.
Do some research, people having problems with axles getting stuck in them, even after Autotech has attempted to repair it several times. Maybe they fixed it with the current batch though.
Nsane1
11
Jun 23, 2004 04:02 PM
Kaizen
Jul 16, 2003 07:52 PM
crxtreme27
Mar 24, 2003 10:24 AM
1506
Jan 16, 2003 12:01 PM
KekeK-18
Oct 22, 2001 01:23 AM
