vtec sputter
Old Aug 26, 2009 | 04:26 PM
hojoR's Avatar
Default vtec sputter
00 honda civic coupe w/b18c. My vtech kicks in then will sputter in and out of vtech. does not always do this. doesnt seemed to be at a certain rpm, just random. I have had the motor in for 4 years. just started to do this the past two weeks. What might cause this and what can I do to fix it? I did a search but with no luck. any help is appreciated. thanks.
Old Aug 26, 2009 | 04:42 PM
ej1love's Avatar
Default Re: vtech sputter
check oil levels first off...
Scott.'s Avatar
vtec
check your oil?
ej1love's Avatar
yea its vtec
Old Aug 26, 2009 | 05:32 PM
hojoR's Avatar
Yikes! Thanks alot! my oil was a quart and a half low! Never had my oil get any wheres close to being that low before. Ill have to keep a better eye on that in the future. Vtec seems to be working perfect now. Thanks again, I appreciate it!
Old Aug 26, 2009 | 05:33 PM
ej1love's Avatar
lol, no problem...
Old Aug 27, 2009 | 07:15 AM
dano88's Avatar
Default Re: vtec sputter
so how does the oil levels make the car do that? because i have a boosted 16a2 and it seems to only do that in 3rd and 4th pulls ?
Old Aug 27, 2009 | 07:21 AM
ej1love's Avatar
more than just oil levels will kill vtec, but most of the time thats why...
Old Aug 27, 2009 | 07:34 AM
helldriver88's Avatar
very true. for instance, your vtec solenoid may be due for a good cleaning. if that metal screen gets clogged up real bad, that will cause vtec to cut out or not engage at all after time.
Old Aug 27, 2009 | 07:38 AM
Sambo_Eddo's Avatar
Wut about loss of power abotu 700rpm before the vtec crossover? then onec vtec has engaged it's as weak as the lower rpm's? I've been faced with this little problem for a while..btw, plenty of oil.
Old Aug 27, 2009 | 07:47 AM
could need cleaned. if its all gummed up it can suffocate it from the proper oil supply, as well as it can cause sensors to not get an accurate reading in the first place. which in the long run can cause your engine to perform funky about the time of vtec crossover. its worth a shot. i used cold oven cleaner, then compressed air to blow it all out. worked like a charm. I also replaced the gasket and screen and vtec hasn't been healthier.
Old Aug 27, 2009 | 09:19 AM
ej1love's Avatar
this is true.
Old Aug 27, 2009 | 09:48 AM
Sambo_Eddo's Avatar
I forgot to mention I'm cammed and on a basemap..haha, I'm sure that has something to do with it also.
3JP
Jun 7, 2010 10:36 PM
tigasin
Nov 14, 2008 11:58 PM
h22a1_julien
Aug 27, 2007 01:44 PM
DC2_ITR
Apr 27, 2007 12:55 PM
spoonef
Feb 28, 2003 10:01 AM
