VTEC Solenoid Activation
Old Aug 26, 2002 | 07:06 AM
xtal's Avatar
Default VTEC Solenoid Activation
Does anyone have the specifications on the VTEC solenoid and what kind of input it expects to activate? e.g. how much current, I am assuming a 12V solenoid, but haven't checked that yet. If anyone has a circuit that's been known to work for this purpose, that would be even better. This is in relation to a H22A4 engine, but I assume the specifications are similar.
Also of interest is if anyone knows the switching circuit that the ECU uses (transistor, relay, what).
Trying to build a poor mans vafc, I have the adc, rpm sampling, dac and micro code done, looking for this last piece.
Thanks muchly.
Steve
Old Aug 26, 2002 | 07:17 AM
CHEETAH's Avatar
Default Re: VTEC Solenoid Activation (xtal)
ECU uses a two transistor circuits, and solenoid needs +12v for activation. Current from transistors is enough to switch solenoid.
Greg
Old Aug 26, 2002 | 07:25 AM
xtal's Avatar
Default Re: VTEC Solenoid Activation (CHEETAH)
Any idea how much current the ECU uses, or the transistor type? If they're using a staged configuration I'd assume that the second transistor is handling a fair bit of current.
Thanks a lot for the info.
Steve
Old Aug 26, 2002 | 09:03 AM
doc's Avatar
doc
I don't know the current, but you can messure the resistance of the vtec value (the spool of it) and calculate it yourself. The transisitors in the honda ecu is a japanese transistor, i think it's not a usual part.
I've build a self-made vtec controller using a TIP125 power transistor to activate the vtec valve. This transistor is common and works fine.
Doc
Old Aug 26, 2002 | 09:41 AM
xtal's Avatar
Default Re: VTEC Solenoid Activation (doc)
A TIP125 will work, good, I have a bunch of TIP122's lying around that should work well then. Probably overkill even. Thanks for all the help.
Steve
matt2320
25
Apr 3, 2021 03:33 AM
tgjg19
Aug 17, 2009 07:41 PM
nfinitecc
Nov 14, 2004 09:21 PM
UndergroundVR-4
Mar 14, 2003 02:58 PM
311
Oct 2, 2002 04:06 AM
