Shift Linkage problem
Old Aug 21, 2009 | 11:39 AM
motrayEG6's Avatar
Default Shift Linkage problem
is there a special way to get the shift linkage out? my motor is a b18c and lsd tranny if that matters. any help is welcome
Old Aug 21, 2009 | 11:58 AM
ISOL2K7's Avatar
New User
Default Re: Shift Linkage problem
OFF THE TRANNY OR THE CAR
Old Aug 21, 2009 | 12:30 PM
motrayEG6's Avatar
out of the tranny
Old Aug 21, 2009 | 01:45 PM
TypeRMOBBiN209's Avatar
well for one piece you just have to remove the bolt...for the other you have to move the boot out of the way and get that little horseshoe looking clip thing off
then comes the bitch pin...its a little pin inside
you gotta bang that out
Old Aug 21, 2009 | 02:56 PM
Corksil's Avatar
yeh, the metal clip around the linkage arm hides the pin through the middle. And the rubber booty hides them both.
Old Aug 21, 2009 | 03:03 PM
98civdx's Avatar
Master Detailer
pop that bolt off,
the there is a snap ring,(90% sure), pop that off, grab a 8mm or 1/4 inch punch and hammer and start beating on that pin when it pops out grab, bag it,tag it and dont loose it.
linage will then come right off.
Old Aug 21, 2009 | 05:01 PM
motrayEG6's Avatar
right on i looked right at that bolt today to, thanks for the help guys
Old Aug 21, 2009 | 05:08 PM
mcjchonda's Avatar
yea on the b series i thought both were connected with 12 mm bolts only the d series use that pin and if its the pin good luck that thing is a pain sometimes 2 get off
Old Aug 21, 2009 | 05:10 PM
Corksil's Avatar
b-series could be two bolts and no evil pins.. I changed the clutch on my dads d15 and it had a pin on the tranny and a bolt on the shifter.
I've never looked under my b-series...
Old Aug 21, 2009 | 05:12 PM
TorquelessEM1's Avatar
Oh,it has the pin........................
Dr.Fixit
Oct 22, 2013 12:42 AM
Civ-dx-96
13
Mar 4, 2013 04:18 PM
MikeY326
Dec 27, 2009 10:35 PM
stegon78
Jun 24, 2005 08:46 AM
eghatchproject
12
Nov 22, 2003 08:28 AM
