Catch can smoke/steam(video)
Old Aug 20, 2009 | 02:34 PM
bchap's Avatar
Default Catch can smoke/steam(video)
I read that its normal to have some steam/smoke coming from your catch can and I'd like to know if the ammount that is coming from mine is normal or if I should be concerned about blow by. Motor is a dohc zv mildly built for boost but has not seen any boost yet. 15-20 000kms on the motor. Anyway heres the video.
Old Aug 20, 2009 | 02:41 PM
b20beast83's Avatar
Default Re: Catch can smoke/steam(video)
looks like blowby to me
b20beast83's Avatar
you should do a compression test
Old Aug 20, 2009 | 02:42 PM
narfdanarf's Avatar
That's more than normal if you are just idling.
Old Aug 20, 2009 | 02:53 PM
PNK SLP's Avatar
thats how mine was smoking...not sure why but even the compression keep can back normal, so it could be ok??
Old Aug 20, 2009 | 02:56 PM
TDautowerkes's Avatar
That exhaust sounds like a whoopie cushion orgy!
Old Aug 20, 2009 | 03:18 PM
bchap's Avatar
Can you say that a little more clearly haha? So yours smoked like that and it wasn't loosing any oil and the compression was fine?
And the exhaust sounds nothing like that haha, just shitty phone video and shitty photobucket quality conbined I guess.
The video was taken at idle after a few good revs.
Old Aug 20, 2009 | 03:28 PM
PNK SLP's Avatar
well when I drive my civic around and i open the hood it smokes just like yours if not more. But I know im running way to rich and need a new tune. But im not loosing oil or buring it, and yes i just had a compression check done and it was 100% normal.
Old Aug 20, 2009 | 03:39 PM
StolenTeg's Avatar
Mine smoke more than that :p especially when the motor is cold
Old Aug 20, 2009 | 05:47 PM
tegman23's Avatar
why do you have a catch can on an all motor ls? lol...My integra will do that after i go up the track come back and pop my hood it will have a little smoke out of the filter like that
Old Aug 20, 2009 | 05:58 PM
bchap's Avatar
It has a catch can because it's getting boosted. Good to hear that this happens to others and all is good, I'm pretty sure I'm running rich also, i can smell quiet a bit of unburnt fuel alot of the time. Still going to a compression test in the near future. Gonna also do an oil change then drive it a bunch to see if I'm loosing any oil. Hopefully I won't have to do a rebuild before it even see's boost haha.
Old Aug 20, 2009 | 06:25 PM
kte324's Avatar
I have seen a few all motor setups use catch cans. I had asked the same thing and they said it lowers the crankcase pressures which allow the piston to move back and forth easier.
Old Aug 20, 2009 | 06:45 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
normal,the end
Old Aug 20, 2009 | 07:08 PM
bchap's Avatar
Well this thread went from very negative to very positive, awesome.
Old Aug 20, 2009 | 07:48 PM
cloviskilla's Avatar
normal ring wear.
Old Aug 20, 2009 | 08:48 PM
90blackcrx's Avatar
Do a leak down on it just for the sake of knowing how healthy the motor is.
Old Aug 20, 2009 | 08:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
^^^ definatly. brand new motors get blow by
Old Aug 20, 2009 | 09:20 PM
kccord's Avatar
x2 For those people who said their motor doesn't have blow by is rubbish. New motors have blow by thus the pcv system.
Try this, open you oil cap while your engine running hot or cold, I'm highly sure that air would puff out. And the fact that our cars have over head cams means that as those cams are turning it displaces air, in which you feel puffing out. I tested this on my dad's new mazda 3, It puffs out air like my accord. I tested my friends LS3 & LS5 V8's & no air coming out since it is push rods.
Old Aug 20, 2009 | 09:37 PM
90blackcrx's Avatar
Not saying they don't , but a leak down test is a good way to see how well the engine is sealing. A small percentage is leak down is ok, but once you start passing that number you know something is up with that cylinder.
Old Aug 20, 2009 | 09:50 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
lol...no i wasn't telling you I was adding a comment. hehe. i know you know all of that.
I should have put *op* brand new motors have blow by
Old Aug 21, 2009 | 10:55 AM
b16-t's Avatar
depends on the built ( my built is loose and smokes too)
vipokc
Feb 4, 2009 06:57 AM
jdmek2277
17
Feb 2, 2009 08:12 PM
AndrewHuffman
Sep 18, 2008 06:17 PM
t0kyoStatus
35
Jun 28, 2008 11:58 AM
VNTEC
May 22, 2004 08:23 PM
