Clunk clunk clunk!
Old Aug 20, 2009 | 09:54 AM
sde780's Avatar
Default Clunk clunk clunk!
My 98 civic sedan makes a clunking noise if you jerk the wheel to the right. You can spin it to the left a little, then spin to the right and it'll make a clunking noise. I thought it was axles but just replaced that and it's still there. Any ideas?
Old Aug 20, 2009 | 09:59 AM
kct01's Avatar
Default Re: Clunk clunk clunk!
check the shocks!!
Old Aug 20, 2009 | 10:10 AM
sde780's Avatar
Why shocks? They are fine, not a moving part...car has 60K on chassis
If I turn the wheel to the right suddenly it'll make a sound, regardless of how far I have it turned. Like something pops when I turn the wheel to the right. Can't re-create it with car on jackstands, I need the wheels on the ground to make the noise.
And I can feel the pop with my feet on the pedals, so it's not just a sound
Old Aug 20, 2009 | 10:45 AM
thumper64's Avatar
Check your bushings. My Blox LCAs made that sound a few months after installing them. Blox for the loss!
If the bolt isn't centered in the bushing, replace it and check if anything is loose.
Old Aug 20, 2009 | 10:50 AM
sde780's Avatar
Hmm OK I'll check those out, could it be my tie rod ends, balljoints, or the steering rack? I just don't want it to fail on me driving, gotta make a 600 mile road trip soon
Old Aug 20, 2009 | 12:49 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
axles...
Old Aug 20, 2009 | 05:35 PM
sde780's Avatar
Brand new reman axles from Advanced auto
Old Aug 20, 2009 | 05:38 PM
Gunmetal_B20_Hatch's Avatar
check universal joints on your steering column for excess play..
earlylocks's Avatar
sway bar maybe broken...i'm pretty sure thats it! had the same problem and took off the mounts holding the sway bar and it was broken exactly at the mounting point, wont be able to tell unless you take the whole thing off!!!
Old Aug 20, 2009 | 10:31 PM
98civdx's Avatar
Master Detailer
hmm could your wheels be loose?
i had this problem when i was too lazy to check them.
Old Aug 20, 2009 | 10:34 PM
spags930's Avatar
baII joints, rack pIay, Iink pins, inner or outer tie rods check them aII for pIay
Old Sep 1, 2009 | 06:00 PM
sde780's Avatar
So I can't tell visually?
Wheels are tightened to like 90ftlbs
The wheels wiggle horizontally
Old Sep 1, 2009 | 06:22 PM
joelmatt89's Avatar
on for this thread mine did the same thing and it has gotten worse know it does it when i turn left as well. It does it the most when i haven't driven for a while hbu, have you noticed that?
Old Sep 1, 2009 | 06:57 PM
earlylocks's Avatar
nope you will not be able to tell visually, gotta take it off, just do take it apart for inspection, its not hard...lemme know how it turns out!
Old Sep 1, 2009 | 07:36 PM
red_crx_89's Avatar
Problem is you bought your axles from Advance Auto
Old Sep 1, 2009 | 08:04 PM
thumper64's Avatar
Axles from Advance are fine. I have yet to have an issue with a part from Advance.
If wheels wobble horizontally (hands at 3 and 9) it's tie rod ends. Spend the money for Moog ones, they have a lifetime warranty. Moog is a division of Federal Mogul, who makes a lot of OEM parts for different car companies. They make Hastings rings, Moog suspension parts, Wagner brake parts...
Old Apr 1, 2010 | 04:22 AM
Oz123's Avatar
TRIAL USER
My 2002 Civic is also making extactly the same clunk noise when turning and also can not be reproduced when jacked up.
So what is exactly the problem???
P.S. I'm not convinced it is the axles or the CV joints since I used to have a faulty CV joints in one of my other cars and the noise was totally different.
swizz977
23
Feb 21, 2013 01:45 PM
BrayzieEF9
20
Feb 13, 2010 05:51 PM
Sic_DA_Nine
Jun 28, 2006 04:53 PM
stew18564
Apr 24, 2004 09:21 AM
DrunkenSailor
20
Apr 13, 2002 10:20 PM
