thumping noise...
thumping noise...
i have a thumping noise coming definately coming from the back of the car...i did a tire rotation and its still doin git, i feel the thumping in the steering wheel at 60ish mph but also at slow rolling...i jacked up each back wheel, the right turns easier then the left turns alittle less free and rubs 1 time per full revolution...could it be a warped rotar? could a warped rotar cause a wobble feeling while driving and also cause the steering to shake at high speed?
anyone help if you can
stew
stew
Re: thumping noise... (stew18564)
Take a gander at your tie rod ends, inspect your wheel bearings, check all bushings and components, and replace as necessary. The front LCA has a bushing that has a tendency to crack and erode, and it causes this horrible popping noise.
