Good power gains for me ls-t
Old Aug 20, 2009 | 05:30 AM
Sticky2K's Avatar
Default Good power gains for me ls-t
Hey guys I guess I need some input on some mods to my setup I know that I can upgrade the downpipe and get a bigger turbo and what not but don’t really want to mess with that at the moment. So what are some good upgrades I can do to my setup?
Integra Ls
18g greddy -12psi
Greddy downpipe
Vortech Bov
440dsm Injectors
Skunk2 intake manifold
2’5in crushed bent exhaust/w twin loop muffler
Intercooler is in pretty bad shape.
Right now im making 220 on a dynamic dyno, I was going to pick up a thermal 3in exhaust this weekend. Should I get another tune?
Old Aug 20, 2009 | 06:46 AM
DA TeG 90's Avatar
Default Re: Good power gains for me ls-t
Just a 3 inch exhaust will help you make more power.
Old Aug 20, 2009 | 07:35 AM
AJxr's Avatar
cams, 18psi of boost or whatever gets your injectors close to maxed out.
Old Aug 20, 2009 | 07:43 AM
solo227's Avatar
3 inch exhaust and bump up the boost to like 15psi... make sure you stay on top of your injector duty cycle...
everythign else is gonna require a new turbo or manifold
Old Aug 20, 2009 | 07:58 AM
Sticky2K's Avatar
would a skunk2 throttle body help? we tried pushing more boost but my tuner told me anything about 12 psi was not efficient. we went to 14psi and it was giving me 5 more whp
Old Aug 20, 2009 | 07:59 AM
blackeg's Avatar
stock fuel pressure you'd probably start to run the injectors too much around 15-17 psi or just about 300hp. id just check the afrs and spark plugs after u swap the exhaust to 3". if you are running leaner than like 12.2:1 id go for a lil retune
kyden's Avatar
it will not help. theres too much backpressure on that turbo with your exhaust setup.
Old Aug 20, 2009 | 08:00 AM
Sticky2K's Avatar
If i were to get cams, wouldnt i need valves and retainers?i also have a walboro fuel pump
Old Aug 20, 2009 | 09:17 AM
TheShodan's Avatar
Moderator
Cams and throttlebodies are last, and even then, with a larger turbo than what you have. Better downpipe, exhaust, larger injectors w/ a new tune would be needed.
You'll need to figure out what your ultimate use and power goals are before we can speculate any further. What are you trying to with this car?
Old Aug 20, 2009 | 11:09 AM
Sticky2K's Avatar
my goal is maybe 280 at the most. i
Old Aug 20, 2009 | 02:08 PM
desiromeo812's Avatar
how much torque did you make at 12psi?
You should replace the greddy DP... you will net about 15whp from that and that crush bent exhaust is also a restriction. It flows like a 2.25 incher. Get a manderel bent exhaust and a better DP.. you will pick up about 15-25 hp easily.
Old Aug 21, 2009 | 06:08 AM
Sticky2K's Avatar
i was making 205 trq. yea hopefully ill pick up an exshust this week
Old Aug 21, 2009 | 07:57 PM
EARLdaSQUIRREL's Avatar
official honda whore
get the dp from kteller and do the thermal 3", go back for a retune and turn up the boost untill you cant make any more power
Old Aug 21, 2009 | 08:41 PM
LightningTeg's Avatar
Community Builder
A 3" exhaust or even a Cutout will help alot.
Do you have a dyno sheet? Id like to see it.
mrbsponge
Apr 11, 2011 01:56 PM
TooSmooth
Jul 20, 2010 08:42 PM
B00STED Si
Jun 12, 2005 02:00 PM
B00ST2nR
Jun 27, 2004 12:57 PM
blackriceman
Apr 27, 2004 05:37 AM
