help with gt35r build
Old Aug 21, 2009 | 01:07 PM
seldon's Avatar
Default help with gt35r build
hey i'm new to the turbo side of things, i'm doing a ls/vtec turbo build and needs some opinions, heres my setup so far.
golden eagle sleeved 84mm b series block
je 9:1 compression pistons and eagle h beam rods, arp rod bolts and head studs.
b16 head
ported and polished
skunk2 pro1 cams
skunk2 pro valvetrain
skunk2 pro series intake manifold
gt35r turbo
top mount manifold
my goal is to make around 400-450whp
Old Aug 21, 2009 | 01:19 PM
mtber's Avatar
Default Re: help with gt35r build
What engine management will you be running ?
What injectors ?
What fuel system ?
The cams maybe a bit overkill for your goals & your turbo, but they should work.
Old Aug 21, 2009 | 08:44 PM
Turbo_TONY's Avatar
why 35r for only 450whp? planning to go for more later? you might check out a GT30 or bw s258 or bw s256 if not.
Old Aug 21, 2009 | 09:22 PM
seldon's Avatar
well i have not decided on fuel management or injector size, i would be more then happy if it made more power
Old Aug 21, 2009 | 09:54 PM
BADGUYNY's Avatar
with a GT35R your more than capable of making more power.... you can see power in excess of 600 with your turbo
Kompressorbengt
Mar 1, 2016 04:44 PM
XxRoCkMaNxNEOxX
May 6, 2010 10:12 AM
benny101
Oct 18, 2009 11:27 AM
bubblevic
Jan 28, 2008 11:54 AM
Fezzie
Sep 13, 2006 07:03 PM
