?? Studs or bolts for manilfold to turbo
Old Aug 19, 2009 | 06:08 PM
oodie's Avatar
Default ?? Studs or bolts for manilfold to turbo
I been fighting with this problem of my bolts backing out of my manifold thus causing leak. I been debating to swich to studs with locking nuts. Is this best way to go. Also my bolts i use are M8 1.25 30mm am i using right size or its that my problem? Any input would be great
Old Aug 19, 2009 | 07:15 PM
boost4life's Avatar
Default Re: ?? Studs or bolts for manilfold to turbo
lock washers are the way to go, and i like a little anti seize to. studs or not thats up to you
Old Aug 19, 2009 | 07:33 PM
turbohatch96y7's Avatar
lock washers are no good on aluminum read a honda guide.they will strip ur head. Maybe try 2 nuts on the stud if u got room or thread lock. Just let it dry before starting ur car
Old Aug 19, 2009 | 08:51 PM
oodie's Avatar
I have put Locktight and let dry on them but I dont think it did anything.
oodie's Avatar
Also is my bolt sizing correct?
Old Aug 19, 2009 | 09:49 PM
project dc2's Avatar
studs all the way
Old Aug 20, 2009 | 09:31 AM
raene's Avatar
Since I started using these, I've had zero problems.
http://www.nordlock.com/
Old Aug 20, 2009 | 01:41 PM
Bailhatch's Avatar
m8 x1.25 is what goes into the head but your title says that you want to know about manifold to turbo which are often 3/8 x 16tpi. I use 3/8" studs on the turbo to manifold connection with long brass nuts. They never come loose and don't seize up like steel does. I have used these on lots of different cars with good luck.
Old Aug 20, 2009 | 04:51 PM
SykVSyx's Avatar
Well, hello, Thomas.
I would suggest you check your pm.
Old Aug 20, 2009 | 10:54 PM
oodie's Avatar
Thanks
Sprockets
Dec 4, 2011 07:15 PM
Silvertc
Jul 21, 2010 10:48 AM
mrx
Aug 9, 2005 10:56 AM
FredoSP
Jan 19, 2004 07:09 PM
Full-Race Geoff
Sep 24, 2002 12:36 AM
