Valve Adjustment Problem
Old Aug 25, 2002 | 02:28 PM
sptsi00's Avatar
Default Valve Adjustment Problem
I just finished adjusting my valves on my 2000 Civic SI and now when I start the engine, I can hear a "tapping" or "ticking" noise. I'm guessing that noise is coming from my valves??? Also I would like to mention:
1. that one of the outer screw caps broke off the head cover, which may be import.
2. I did use the appropriate feeler gauges (.006 for intake and .008 for exhaust)
3. I also used the appropriate valve adjusting tool.
4. I didn't replace the high temp sealant for the rubber lining.
Old Aug 25, 2002 | 03:43 PM
bluedelsol's Avatar
Default Re: Valve Adjustment Problem (sptsi00)
the tapping coming from your engin is because one of your valves is stuck in the open position and the tapping is when the cam goes around and taps the end of it, you just need to open it up again and make shure your valves are lubbed correctly, you may beable to see witch one is stuck and just fix that one.
Old Aug 25, 2002 | 04:07 PM
BoredNStroked's Avatar
Default Re: Valve Adjustment Problem (bluedelsol)
Ummm......no.....the valves dont get stuck open......WTF are you smokin? The cam doesnt even hit the valve directly...It moves the rocker arm which intern moves the valve.....He set the exhaust to .008, it should be .007.....could be the noise??...but more than likely the noise is because the adjustment was done improperly for one reason or another.
Old Aug 25, 2002 | 04:17 PM
Loco Honkey's Avatar
Default Re: Valve Adjustment Problem (BoredNStroked)
I'll second that motion.
and for good info.
and for bad info.
Old Aug 25, 2002 | 04:42 PM
bluedelsol's Avatar
what the hell.., sorry about that, that was my retarded friend on my name, i agree with what you said, my friend is a ******* dumb ***
Jax4gencivic
Jan 17, 2023 06:41 PM
d17beast
Honda Civic (2001 - 2005)
Nov 12, 2010 03:12 PM
rlj51
Apr 9, 2003 01:48 PM
Yuleluder
Aug 29, 2002 07:20 PM
raene
Jun 27, 2001 10:45 PM
