Valve Clearance problem!
Old Aug 28, 2002 | 11:49 AM
Yuleluder's Avatar
Default Valve Clearance problem!
I've got this valve tapping away, I adjusted the clearance to .015mm and it's still tapping away. I did it in the morning before the engine was started. I've got the Helms manual and I did how they explained. Should I tighten them down even more. I did have the head sent out to Gude could this affect the tolerances?
Old Aug 29, 2002 | 07:50 AM
illusion's Avatar
Default Re: Valve Clearance problem! (Yuleluder)
valve tap noise is common on hondas to begin with. even after i adjusted my valves it still made the noise.
Old Aug 29, 2002 | 04:20 PM
Yuleluder's Avatar
Default Re: Valve Clearance problem! (illusion)
I really don't think it should be making this noise!
Old Aug 29, 2002 | 05:55 PM
4bidden's Avatar
you can safely take .001 to .002 off of the honda measurements if you want the tick to go away
Old Aug 29, 2002 | 07:08 PM
satan_srv's Avatar
Hmm I just had a valve adjustment today. I mean it still taps but I barely notice it...
Old Aug 29, 2002 | 07:20 PM
4bidden's Avatar
Default Re: Valve Clearance problem! (satan_srv)
i do my valves .005 intake and .006 exhaust
d17beast
Honda Civic (2001 - 2005)
Nov 12, 2010 03:12 PM
frank2660
May 7, 2006 06:17 PM
acurateg96
Feb 6, 2006 03:24 AM
mattymatt
Aug 4, 2001 04:39 PM
raene
Jun 27, 2001 10:45 PM
