CLutch problem
Old Aug 13, 2009 | 01:23 PM
BlkCivicFromTeamMNR.com's Avatar
Default CLutch problem
I had been having slave cylinder problems so I replaced my old one with a new one....The night before I replaced it i heard a loud squeaking sound like wet belts when i engage the clutch and my rpms would drop(when n neutral) and sometimes cut the car off....then when i did the slave cylinder replacement the sound is still there and now my clutch pedal has a vibration PLUS it wont go into gear when the car is on. when I put it in gear and then try to start it holding the clutch in the Car trys to go forward.....
I need someone to tell me whats going on the clutch is about a year old a few passes at the track last year and thats it just everyday driving no burn outs the clutch it self wasnt nor has ever slipped....
HELP ME OUT PLEASE!! THANKS IN ADVANCE!!!
BUMO IF READ BUT HAVE NO ANSWER
Old Aug 13, 2009 | 02:06 PM
B-outAteam's Avatar
Default Re: CLutch problem
maybe u need a new clutch master clylinder
Old Aug 13, 2009 | 03:40 PM
is there a way to check that?
Old Aug 13, 2009 | 10:35 PM
ttt..........
Old Aug 14, 2009 | 08:33 AM
help please
Old Aug 14, 2009 | 08:48 AM
tico's Avatar
well first off did u bleed the system properly? and did you use breand new brake fluid?
Old Aug 15, 2009 | 09:29 AM
lol Im not a noob homie!! Yes Bleed the system properly and completely and Yes used Brand new Dot3.....
DenisR
Feb 19, 2016 05:09 PM
favd21
Transmission & Drivetrain
Sep 8, 2012 03:00 PM
06typeSEX
12
Jun 1, 2009 02:12 PM
TnLude2000
Feb 27, 2005 02:32 PM
ls95hatch
May 24, 2003 09:34 PM
