em1 problem accelarating
Old Aug 11, 2009 | 03:12 PM
bossm's Avatar
Default em1 problem accelarating
yea well i have a problem accelarating with my em1......anyways after regular crusing at around 3-5krpm it will just stop at 3-5000rpm and itr feels like it does not want to go as soomeone is holding it back and when i hit the gas slightly more the it will get a deep tone but stay at a certain rpm and then it starts bucking and jerking but it only does it at regular crusing........it is not throwing any cels but the o2sensor......
Old Aug 11, 2009 | 03:26 PM
Former User's Avatar
Default Re: em1 problem accelarating
What shape are the plugs, wires, cap, and rotor?
Is the ignition timing set to spec?
In some cases, a faulty O2 sensor may cause the engine to run too lean, resulting in such performance problems.
Old Aug 11, 2009 | 03:30 PM
bossm's Avatar
brand new plugs,wires,oil,and yea i have stock obd2 ecu and then i have a hondatats300 and it does it on both of them......and it will only do it on crusing the car runs perfectly at wot
Old Aug 11, 2009 | 03:33 PM
Inspect the cap and rotor and check the ignition timing.
What O2 sensor code are you throwing? Do you know whether the sensor or wiring is the problem? Do both ECUs throw the O2 sensor code? Does unplugging the O2 sensor make the problem go away?
Old Aug 11, 2009 | 03:35 PM
bossm's Avatar
k yea its only throwing it on the stock obd2 ecu on the hondata im not throwing any codes and i just checked the cap and ignition timing is stock
Old Aug 11, 2009 | 03:37 PM
bossm's Avatar
actually on the s300 it was showing a faulty knock sensor which we disabled
Old Aug 11, 2009 | 03:38 PM
bossm's Avatar
ow and the secondary o2 sensor that goes into the cat is not screwed in it has been removed
Did you inspect the contact points inside the cap and on the rotor?
Are you using a timing gun with the service connector jumped to check the ignition timing?
Is the CEL code for the primary or secondary O2 sensor? Edit: So the primary O2 sensor is not throwing a code, right?
Old Aug 11, 2009 | 03:43 PM
bossm's Avatar
its the secondary 03 sensor
and yea i have checked the contact points and the roto seems fine
and no i got the timing checked last week and everything was fine......
Old Aug 11, 2009 | 03:46 PM
Okay, then you might want to check the ICM and coil in the distributor. Also consider a Seafoam treatment. How's the fuel pressure with and without the FPR vacuum hose connected?
Old Aug 12, 2009 | 10:02 AM
bossm's Avatar
the distributor is perfectly fine there is nothing wrong with it...............and the fuel pressure is fine its at 55
ramseybd6
Aug 17, 2009 12:27 PM
candymanjl
Oct 6, 2006 03:41 AM
johnny_tdi
May 11, 2006 10:10 PM
apok
May 16, 2005 09:52 PM
johnzm
Jul 7, 2002 05:19 PM
