Instrument panel problem
Old Aug 7, 2009 | 06:36 PM
powerpro_69's Avatar
Default Instrument panel problem
so i have no cluster lights all the warning lights work dimmer switch is good and so is the dimmer relay all the bulbs look good what else could it be
Old Aug 7, 2009 | 06:48 PM
pumpkin129's Avatar
Default Re: Instrument panel problem
fuse maybe
Old Aug 7, 2009 | 06:51 PM
all fuses are good changed them all clock works radio works took it out to see if thats the problem still not working all wires at radio are good no striped or hacked wires
Old Aug 10, 2009 | 06:58 PM
BUMP anymore ideas
Old Aug 13, 2009 | 08:31 PM
ok so when i try to dim the lights the switch doesnt work i have tried 2 switches and 2 relays and nothing at all now
Old Aug 13, 2009 | 08:36 PM
grog's Avatar
check the wiring for the switch. inspect the back of your cluster look for burned traces or anything abnormal
Old Aug 18, 2009 | 03:17 PM
got it all figured out
Old Aug 18, 2009 | 03:50 PM
grog's Avatar
so do you mind telling us what it was?
Old Aug 26, 2009 | 07:57 AM
had no power to the switch from the fuse box replaced the fuse box works fine now
rodney88
May 21, 2013 04:39 PM
KINGVEM^^ED6
May 18, 2013 06:17 AM
awdgsx96
12
Sep 21, 2009 07:31 PM
LOLyouhavefakewheels
11
Feb 1, 2006 07:28 PM
kaoticimports
May 31, 2004 08:53 PM
