Cluster, Turn Sisgnal and Clock all stoped working
As the title says, my cluster lights still work and my hazard lights still work so its not the relay. I checked all my under hood and underdash fuses and they're all fine. Is there a fuse that controls the cluster, signals, and clock. The car is a 1995 Civic Si-R (Japanese model)
Re: (mrbigg9032)
I checked each fuse about 3 times now and they're all good. My back up lights are also not working but my back up fuse is fine. From the research that I've done i think I have a bad ground, but I have no idea where the ground cable is for the signals.
Re: (CivicB18C5)
me and my cousin found out one night(the hard way off takin the dash apart) that the hazard switch controls the turn signals,cluster lights, and radio bezel light
In a Junkyard near you.
Your right the switch is after the relay so it's probably good. I would suspect the switch itself because each light has it's own ground.
Does the clock do anything at all?
Re: (CivicB18C5)
I installed a whole new gauge cluster and it still isn't working. Is there a fuse or a ground that the signals,cluster, reverse lights, and clock are hooked up to? I'm pretty sure thats my problem.
looxs
11
02-05-2007 04:06 PM
JDMlyfestyle
11-20-2005 07:21 PM
prelude1897
04-27-2005 11:09 AM
