lighting problem
Old May 12, 2013 | 06:58 PM
rodney88's Avatar
Default lighting problem
Hows it going so I'm having an issue with my accord my running lights aren't working I have brake lights, headlights,and turn signals but no running lights can't figure it out. Anyone have any ideas already checked fuses gauge cluster lights don't work either when I turn the lights on
Old May 13, 2013 | 06:14 PM
Lost Again's Avatar
Default Re: lighting problem
Have you tested the dimmer switch?
Old May 20, 2013 | 06:20 AM
rodney88's Avatar
I have not tested the dimmer switch I did replace the combo switch I did notice its blowing the small light fuse can't track it down what is that fuse for I've tried googling it I'm having a hard time finding it
Old May 20, 2013 | 06:27 AM
rodney88's Avatar
Old May 20, 2013 | 06:52 AM
TheMuffinMan's Avatar
He knows where you live!
Guess what's all tied into that fuse you're blowing?
Find the issue for the fuse, you fix your problem.
Old May 21, 2013 | 04:39 PM
joey2talk2's Avatar
I fixed that issue with DRL in my accord by removing the DRL control box and opening it up and fixing 6 cold solder joints!!! Not even my mechanic could figure that one out
acracer2008
Nov 1, 2010 11:14 AM
dtenakoun
Nov 30, 2008 11:13 AM
CooBreeze
Oct 19, 2007 05:53 PM
