chipped ecu
my ecu is chipped/tuned for 7 psi boost right now and i'm trying to set it back to stock. it looks like this right now...
my question is if i were to take the chip that's circled out, would that set it back to stock settings or do i need to put something back in it's place?
Why do you want to go back to stock? Why not just get a base-map chip? That way you won't have a cut wire if you ever want to use the socket again.
You can cut that wire, you'll just have to solder in a new one. Otherwise when you do put in a new jumper, do it the right way with an actual jumper with removable plug.
Or you can get a stock basemap burned on to a different ROM.
if i was you id get a j1 soldered in with a removable dealy so you dont have to keep taking chips in and out. getting chips out will get them messed up and possibly rip out the socket..yeah. i broke 2 good chips last month..oh well
i found out today looking at my ecu again that i can just pop the chip in and out. it's just held in place by a thing that has a flip switch that it slides into.
now, if i just pop the chip out, will i be back to stock or would i have to get a base map chip to put back in?
Ask this company:
http://www.phearable.net/contact.html
They sell custom basemaps on another page on their site, but they don't mention stock basemaps. I'm sure if you ask for a stock basemap they can make you a chip with one on it though.
scrambled_EG
Engine Management and Tuning
May 14, 2009 07:13 AM
LS stretch
Feb 3, 2009 08:40 AM
