chipped ecu to stock edu
Old Apr 29, 2007 | 01:43 PM
tubed-ef's Avatar
Default chipped ecu to stock edu
I have a chipped p28 ecu for my d15b7, wondering how i can change everything back to stock, get a new ecu or get a chip from another ecu?
Old Apr 29, 2007 | 07:29 PM
BEST1TUNING.COM's Avatar
Default Re: chipped ecu to stock edu (tubed-ef)
this is simple if you do it right. It only involves one thing.
Open up the ecu. look at the side of the chip oposite the side close to the edge of the case. You will see a plain jumper wire at label J1. If you cut this jumper it will go back to a stock p28, you dont even have to remove the chip. Let me know if you need more help.
Old May 2, 2007 | 04:35 AM
tubed-ef's Avatar
Default Re: chipped ecu to stock edu (BEST1TUNING.COM)
was completley thinking about my other car when i asked this its a PM6 ecu with turbo edit? now what do i do kinda lost.
Modified by tubed-ef at 5:57 AM 5/2/2007
Old May 2, 2007 | 11:35 AM
sanimalp's Avatar
$cat /dev/urandom
unfortunatly for you, since your ecu is a pm6 and not a p28, it means you have to get the chip reflashed. the good news is that the stock rom can be found on pgmfi.org. you may be able to buy a ship with the stock rom on it from someone like xenocron or kenjii or any of the other honda tech chipping people.
scrambled_EG
Engine Management and Tuning
May 14, 2009 07:13 AM
LS stretch
Feb 3, 2009 08:40 AM
grncivic91
Jun 1, 2002 01:25 PM
