ANOTHER ANNOYING OVERHEATING CAR!
Old Aug 1, 2009 | 08:57 PM
R.coustom's Avatar
Default ANOTHER ANNOYING OVERHEATING CAR!
I NEED HELP ASP, PLEASE! I HAVE A 97 HONDA CIVIC EX YESTERDAY THE CAR STARTED OVERHEATING, SO I REPLACE THE THERMOSTAT MY SELF, THINGKING THAT COULD BE THE PROBLEM. BUT AFTER DIVING IT AGAIN TODAY IT OVERHEATED AGAIN, SO I TOOK THE CAR TO THE SHOP AND THEY REPLACE WATER PUMP AND TIMING BELT. SO AFTER EVERITHING REPLACED I TOOK IT FOR A DRIVE AND IT STILL OVERHEATS. WHAT COULD IT BE? I CHECK THE FAN TO SEE IF IT WAS WORKING, ITS ROTATTING WHEN IT GETS TO REGULAR TEMPERATURE, I ALSO REPLACE THE RADIATOR WITH A USED ONE, AND IT KEEPS OVERHEATING. I DONT HAVE ANY MORE IDEAS!
Old Aug 1, 2009 | 09:08 PM
crxboy909's Avatar
Default Re: ANOTHER ANNOYING OVERHEATING CAR!
hmmm well the only thing i can think of doing is a raidiator flush.... flush your whole cooling system out see if that helps.....
Old Aug 1, 2009 | 09:24 PM
R.coustom's Avatar
THNX FOR UR COMENT I REALLY NEED ALL COMENTS, ILL DO THAT TOMORRW. THNX AGAIN.
Old Aug 1, 2009 | 10:16 PM
crxboy909's Avatar
no problem =]
Old Aug 1, 2009 | 11:03 PM
Ruben19's Avatar
make sure you bleed all the air out the cooling system.
try another thermostat cuz some come defective from the manufacture.
if nothing works, blown head gasket
Old Aug 2, 2009 | 06:28 AM
TLo's Avatar
TLo
bleeding all the air out might be the problem but have you been leaking any coolant prior to this problem? if you have that might be the case...
also is there any smoke coming from the tailpipe? it should have a sweet smell to it, usually a white cloud of smoke... if you say yes to this then it is a blown headgasket
you should have had the mechanic who worked on your car checked it out before you got your water pump/timing belt put in...
an easy way to check to see if it really is the thermostat is... warm the car up for 5 to 10 mins (preferably 10 mins to make sure) now at this time the water temp should either raise really high or stay about mid level, what you do is check the coolant line that is farthest down if its warm then the thermostat is working, if its cold then you have a thermostat problem.
Old Aug 2, 2009 | 11:44 AM
R.coustom's Avatar
ok jod done bad thermotat I went and buy another one .thank everyone peace out
Old Mar 20, 2011 | 02:01 PM
bassiss's Avatar
has anyone ver used Dura Seal head gasket repair? For the non tech perso. does it work or no, i dont have lots of cash too get head gasket repoaired just wondering ?
Old Mar 20, 2011 | 04:04 PM
Former User's Avatar
Old thread. Start your own.
tech410
15
Sep 22, 2010 05:22 AM
jmacc8
Honda Civic (2001 - 2005)
Aug 20, 2010 11:52 AM
moosta936
Jul 9, 2007 05:59 PM
CptCorN
28
Feb 6, 2005 06:23 PM
4505
Oct 12, 2003 05:28 PM
