Overheating when stopped
Old 09-19-2010, 04:22 PM
tech410's Avatar
Default Overheating when stopped
Having a problem with overheating. While driving the car, temp is okay. When i pull into my driveway to park the car, temp needle goes up to HOT. When I rev the engine, heat goes down a bit. When the engine is off, coolant just splashes out of the overflow container. Not sure what the problem is. I put in new coolant and changed the temp sensor. Also removed the thermostat. Thanks.
Old 09-19-2010, 04:35 PM
habib's Avatar
Default Re: Overheating problem.
did you bleed the system of air
Old 09-19-2010, 04:53 PM
Two Piece
Go_Race_Your_Self's Avatar
Hmmmm.....
Try checking your water pump, not sure if that could be an issue.
Old 09-19-2010, 05:01 PM
mindlessn00b's Avatar
Well when your driving the air is passing your radiator and pulling some heat away when you parked its not doing that, the fan should be assisting if your not moving.... Is the fan working i'd check that.
Old 09-19-2010, 05:06 PM
Jimster480's Avatar
It sounds like you either have a ton of air bubbles in the system or your headgasket is leaking. I had a similar problem, although oil and water were not mixing until it blew completely. You should check your exhaust with your hand and see if the air coming out of there is very humid, because if it is you could have a HG leak.
Old 09-19-2010, 06:17 PM
Former User's Avatar
Start by checking whether the fan runs when the engine overheats in the driveway.
Old 09-19-2010, 06:33 PM
Bartman201's Avatar
like he said check the fan, also check fan switch.
Old 09-20-2010, 05:54 PM
collin-eg2's Avatar
Default Re: Overheating when stopped
Plugged radiator? I see that all the time at work with those same symptoms
Old 09-20-2010, 06:53 PM
SeanK325's Avatar
can this be done by just running with the cap off?
Old 09-20-2010, 08:20 PM
collin-eg2's Avatar
If their is no bleeder valve
Old 09-21-2010, 12:16 AM
Jones570's Avatar
deff check the water pump
Old 09-21-2010, 02:56 AM
Swervin95EX's Avatar
Also could be the thermostat sticking...
Old 09-21-2010, 05:10 AM
tech410's Avatar
The fans do turn on and I did bleed the system a couple of times. Could the radiator be bad also? The car runs good. I removed the thermostat just to see if there are any changes. The water pump is fairly new, about 200 miles on it. If the radiator is plugged, how do i unplug it?
Old 09-21-2010, 07:29 AM
DanielSLe's Avatar
Originally Posted by Go_Race_Your_Self
Hmmmm.....
The same thing happened to me when i was driving, the temp was fine. But when i was at a stop light or drive thru it would heat up bad. The problem was a faulty water pump.
Old 09-21-2010, 10:28 AM
Ci-v-iC's Avatar
I hope this is not the issue!
Old 09-22-2010, 05:22 AM
tech410's Avatar
I'll try the water pump replacement and see what happens. Thanks for the info.
Erik Tumasyan
12-18-2014 03:18 PM
kodylive
05-01-2013 05:46 AM
84dime
09-16-2009 04:02 PM
helldriver88
01-26-2008 10:33 PM
meanTheDope
11
04-28-2005 05:06 PM
Quick Reply: Overheating when stopped
