Old Gas
Old Aug 1, 2009 | 08:55 PM
Needy4Speed's Avatar
Icon6 Old Gas
I pulled an A4 motor from my '99 lude about two years ago. It was supposed to back in right away, but it turned into a side project and is just about to go back in. What would you recommend doing with the old gas? Should I dump a bottle of seafoam in it, or do I have to siphon it all out? What about the filter and that, do they need to be replaced? The other lines, tank,...........
Old Aug 2, 2009 | 04:36 AM
street_ride14's Avatar
Default Re: Old Gas
I would take the tank completely off and dump the old fuel + clean the insides. No need to really worry about the lines. Get a new fuel filter, I would also get a new fuel pump while you have everything apart.
Old Aug 2, 2009 | 06:35 AM
prion's Avatar
Default Re: Old Gas
If there is not too much gas left, you can put some HEET in the tank and fill it up with premium. If there is a bunch of gas in there, then siphon some out first. Change your fuel filter after you run it if you want to.
My prelude sat for a couple years and that's what I did. No problems with the fuel pump so no need to change it out.
Old Aug 2, 2009 | 08:05 AM
JDM_EK_SiR's Avatar
Default Re: Old Gas
my prelude had sat there for a while w/ old gas, i just put some fuel injector cleaner and filled up again and no problems.
Old Aug 2, 2009 | 07:43 PM
Default Re: Old Gas
Thanks, I appreciate it.
Old Aug 2, 2009 | 10:52 PM
TheJGB3's Avatar
Default Re: Old Gas
BTW - There is a drain plug on the gas tank. On a fifth gen it is located on the drivers side (LH) rear corner.
Tim Manhattan
Apr 21, 2012 08:48 PM
EX-T
Jul 28, 2010 03:46 AM
project91crxsi
Sep 7, 2009 10:14 AM
severs
Jun 27, 2007 01:48 PM
moacsupreme
Jun 28, 2004 11:05 PM
