Yay! another cel post!!
Old Jul 31, 2009 | 01:13 PM
wolf95's Avatar
Default Yay! another cel post!!
ok, so i went to check my cel with the self checker and when i shorted the 2 wire plug my cel just stayed on. it flashed on then off like normal without the paper clip. any tips?? thanks
Old Jul 31, 2009 | 01:15 PM
H23_del_soul's Avatar
Default Re: Yay! another cel post!!
mine does that sometimes, just turn the car off, take the wire out, put it in REALLY good and make LOTS of contact, then turn the car back on
edit :welcome to the CEL party
Old Jul 31, 2009 | 01:19 PM
wolf95's Avatar
tried that 3 times. same result..
Old Jul 31, 2009 | 01:21 PM
hmmmm, have you reset the ecu yet? what year and obd0-1or2? 95 sol right?
Old Jul 31, 2009 | 01:24 PM
wolf95's Avatar
how do i reset an ecu? and i actually dont know what obd0-1or2 means. i've heard it alot but i never got a really good explanation. and ya, 95 del sol si
Old Jul 31, 2009 | 01:37 PM
well 95 means obd 0 or 1, obd is on board diagnostics. the batt needs to be disconnected and take the top second to the right 7.5 amp fuse out of the fusebox under the hood. wait about 20-30 mins and then go connect everything back. then check the CEL.
Old Jul 31, 2009 | 01:38 PM
wolf95's Avatar
ok ill try it and let u know. thanks
Old Jul 31, 2009 | 01:45 PM
wolf95's Avatar
the fuse under the hood-did u mean the 15 amp ecu fuse? cuz there is no 7.5 under the hood
Old Jul 31, 2009 | 03:20 PM
wolf95's Avatar
ok so i reset it and it still stays on with the paper clip in...
Old Jul 31, 2009 | 03:45 PM
hmmmmm, are there 2 different plugs to plug into?
Old Jul 31, 2009 | 03:49 PM
slowhatchcali's Avatar
what do you mean you shorted out the plug? its probably flashing still because there is contact between the two wires
Old Jul 31, 2009 | 03:56 PM
slow96lude's Avatar
there has to be contact between the two wires to read the code. If it is staying solid even with the plug jumped, then that means the ecu is fried. Take the top of the ecu apart and see if you notice and burnt resistor, caps or traces in the board, Top and Bottom
Old Jul 31, 2009 | 03:59 PM
not necessarily, it can also mean there is no codes...
to the OP, does your car run?
Old Jul 31, 2009 | 04:02 PM
slow96lude's Avatar
If you jump the connector and the light doesnt come on, that means there are no codes. It could also be that the common grounds are not contacting properly.
Old Jul 31, 2009 | 04:04 PM
no.. when you jump the connector, and there is no codes, it will give you a solid CEL.. at least thats how civics are.. or obd-1's for that matter
Old Jul 31, 2009 | 04:08 PM
slow96lude's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jul 31, 2009 | 04:10 PM
where does it say anything about having no codes= no lights? i couldnt find it..
Old Jul 31, 2009 | 04:11 PM
Former User's Avatar
This means all is normal and no codes have been thrown.
Old Jul 31, 2009 | 04:13 PM
slow96lude's Avatar
https://honda-tech.com/forums/forced-induction-16/solid-check-engine-light-service-connector-jumpered-460808/
make sure you are jumping the plug then turning the ignition on
My bad slowhatch. The solid even after jumping can mean no codes It can also mean a FUBAR ecu.
Old Jul 31, 2009 | 04:17 PM
https://honda-tech.com/forums/showthread.php?t=460808
yup it can go both ways.. with the first option being the best lol
Old Jul 31, 2009 | 04:23 PM
slow96lude's Avatar
Yea I will cross my finger for the OP. I was reading the thread link I posted and they jumped the ecu with car off and got codes. Also OP make sure you ecu/backup fuse under the hood is good or once you shut the car off to check the codes its reseting the ecu...
Old Jul 31, 2009 | 11:11 PM
wolf95's Avatar
my laptops actin really dumb or id explain the whole story but long story short- my problem i was havin is gone and there is no cel comin on while i drive so were good now. thanks for all the help.
jakl
11
May 14, 2010 11:38 AM
craiger28
Aug 28, 2009 01:27 PM
Choy
21
Jul 27, 2009 06:48 PM
ragnaroek
11
Jul 26, 2005 05:33 AM
VTEC-DA
Nov 29, 2002 01:27 PM
