Need help with B series swap
Old Jul 28, 2009 | 09:25 PM
DARIUSZ - DNPhoto's Avatar
Default Need help with B series swap
First and foremost, thanks in advance for the help.
I recently picked up a USDM Type R and am getting everything sorted out.
I have spent hours reading up on the motor mounts. I am having difficulty uderstanding which mounts i can reuse from my d16y7 in my EK.
From what i understand, driver side mount i need an SiR ( in canada ) / Si (US) mount and bracket. Si tranny rear tranny mount. No ac on motor, si timing side mount. The pass side tranny torque mount is a big "?" and i believe the pass mount is bolt in. Please help me out here. Correct me if i have anything wrong, and what mounts could/should i use.
Also, what else do i need to change to get this motor to fit without any headaches? thanks HT
Old Jul 29, 2009 | 04:18 AM
kyden's Avatar
Default Re: Need help with B series swap
you need the si(r) timing belt mount. you can use your stock bracket and oil filled mount. both torque mount brackets need to be b series, you reuse your stock rubber mounts at the frame rail.
Old Jul 29, 2009 | 03:57 PM
KWayRacing's Avatar
Check out the Hybrid forum for answers or click here https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A%2A%2Aokay-lets-cut-down-repeated-qs-about-certain-swaps-post-links-here%2A%2A%2A-650230/
johnzy00
Dec 15, 2009 02:21 AM
Nicaraguense13
20
Aug 21, 2006 05:01 AM
too much vtAK
May 17, 2006 09:21 PM
Norcalstoppy
Sep 25, 2003 10:16 AM
