Driver Side MOunt help
Need Help witha a B series mount ppl tell me that a 94Up Integra Driver side mount would fit and Solve my bseries Mount problem Is this true??? need HElp with a B series Mount Suggestion or Resolution to my problem
Re: (Nicaraguense13)
use the stock mounts. you need a 99-00 si rear tranny bracket, the d series upper tranny bracket needs to be bolted to the b tranny and the upper driver side bracket. you can use all of your d series rubber mounts.
searching works too, since this question seriously gets posted 5 times a day. im just a nice guy.
Re: Driver Side MOunt help (strictly.business)
but that the Problem Im having PPL are telling me a Integra 94 up those Mounts will be better instead of Buying a Bseries Bracket
Re: Driver Side MOunt help (Nicaraguense13)
the mount bracket that bolts to the head needs to be b series and the rear mount also but other than that u can use all ur stock mounts, if you dont have the ac mount bracket you will need one either off an integra or del sol.
Re: (fkncivic)
http://images.andale.com/f2/10...1.JPG
This is a Del sol B16 Bracket would this work and I saw the LS it this one right??
http://i2.ebayimg.com/04/i/08/0e/46/02_1.JPG
oo yea was wondering is ur car a Ek??? can u send me a Pic of ur Mount???
i have a 98 coupe, it is 4am here so i cant take pics right now cause my digi cam sucks at night but ill try and get them up tomorrow for you.
Re: (fkncivic)
lol that is the mount on the head that you need, i used a b16 one but for your front ac mount if you dont already have it you will need a b series bracket.
Re: Driver Side MOunt help (fkncivic)
the LS one right sry for asking so many questions ITs better to ask and be annoying instead of wasting money and being OFF
its cool man, keep all ur stock chasis mounts, u need a b16 rear mount bracket, a b16 driverside bracket(the one that bolts to the head), and a b series ac mount bracket which is on the very front drivers side of the block.
thanks for the help But juss Incase i need pics LMAO i need to BE RIGHT ON THE DOT WITH ALL of this thanks Bro
ill check my folder tomorrow, i might still have all the part numbers somewhere or ill try and get some pics up. if i fail however, try searchin the archives they might have what you need.
Goes like this for 96-00 civic with a b-series.
-All rubber mounts can be reused.
-Upper tranny bracket can be reused.
-Need rear 99-00 si bracket.
-Need 99-00 si engine block bracket (driver's side) might be able to use LS, but not sure on exact fitment.
-Use b-series hydro front vibration brackets.
4gencivicef9
04-16-2007 04:37 PM
