CAR WONT START !! PLEASE HELP DD
Old Jul 27, 2009 | 06:44 PM
JAYDmManny1331's Avatar
Default CAR WONT START !! PLEASE HELP DD
hey whats up guys im having problems with my car it ran good all weekend no prob its a integra with a b20 turbo saturday night i think someone tried stealing it so sunday night
so to try to prevent the thieves i took two of the spark plug wires off and took them inside with me i dont know if that was stupid but then i cranked it and it turned on the shut of so i tried starting it and wouldnt thats what i wanted but in the morning after i put both the wires back it wouldnt start it was just cranking any sugg maybe i need new wires dis cap spark plugs !!!!!
Old Jul 27, 2009 | 07:03 PM
NikeKiid's Avatar
Default Re: CAR WONT START !! PLEASE HELP DD
you put the spark plugs in wrong...
Old Jul 27, 2009 | 07:34 PM
i didnt take the spark plugs off just the wire and im sure there back correctly
Old Jul 27, 2009 | 08:32 PM
help help help !
Old Jul 27, 2009 | 09:42 PM
NikeKiid's Avatar
you blew you motor
Old Jul 27, 2009 | 09:47 PM
serious
Old Jul 27, 2009 | 09:58 PM
NikeKiid's Avatar
yup
Old Jul 28, 2009 | 07:18 AM
any other input
Old Jul 28, 2009 | 08:30 AM
dephtone's Avatar
Is the fuel pump priming? Are you getting spark from the distributor?
Start out with the small things that you can check easily.
Any Check Engine Lights?
Old Jul 28, 2009 | 01:18 PM
no cel light they told me it might be the coil
Old Jul 28, 2009 | 01:40 PM
System Lord's Avatar
my b20t wont spark and Ive done nearly everything to figure it out. Maybe if you figure it out you can post up what it was. other than that start with your dizzy, fuses under the hood main relay just for starters
Old Jul 28, 2009 | 02:27 PM
sikefcrx89's Avatar
Loved
are you sure you put them back on in the right order? 1342
Old Jul 28, 2009 | 02:38 PM
philafelman's Avatar
yeah, you probably got the order wrong...or maybe the thieves were so pissed at you for taking the wires out, they took something else out to pull a fast one on you.
Old Jul 28, 2009 | 02:45 PM
.:urbandc2:.'s Avatar
so man.. this clearly shows one common problem, CHECK YOUR FIRING ORDER. this problem has nothing to do with your dizzy or your plugs or you blowing up your motor. all you did wrong was put the wiring back in in the wrong order.
Old Jul 28, 2009 | 03:42 PM
il rewire today and see if that helps
Old Jul 28, 2009 | 03:43 PM
anybody have a diagram on how to put the spark plug wires !
Old Jul 28, 2009 | 03:59 PM
sikefcrx89's Avatar
Loved
normally the caps have #1 marked. the go from there in this order 1-3-4-2 clockwise on the cap
Old Jul 28, 2009 | 04:13 PM
cool man il give it a shot tonight
Old Jul 28, 2009 | 05:14 PM
the cap wasnt markd
Old Jul 28, 2009 | 05:30 PM
energ3tic2's Avatar
start at the c ...should have a c on it
Old Jul 28, 2009 | 06:47 PM
https://honda-tech.com/showthread...g+order+series
Old Jul 30, 2009 | 05:33 PM
whats the word????????
Old Nov 22, 2009 | 09:33 PM
domanikills's Avatar
sorry this is kinda late but im pretty sure its ur ignition coil ... when u start ur car with missing spark wires that caused the coil to short its self thus making it useless... also u can check ur module that can be a problem too but on honda's its mainly the i coil that goes bad ..
not sure. just a normal tech here ...
Boosted96gsr
Jan 9, 2012 08:04 PM
smoovekriminal
Aug 17, 2007 09:55 PM
AlexT
Oct 13, 2004 05:45 PM
BrothaSit
Sep 26, 2004 07:15 PM
itsm3paul
May 10, 2004 12:49 PM
