BOV air leak?
Old Jul 26, 2009 | 06:20 PM
jsbayer's Avatar
Default BOV air leak?
At idle, if i put my hand over my BOV, i feel air pushing out...im thinking this is wrong...but, when i snap the throttle, it goes away, almost like a vacuum feeling...so im asking, is my bov leaking? tighten it? etc...thanks
Old Jul 26, 2009 | 06:31 PM
dpetro1's Avatar
Default Re: BOV air leak?
That's normal
Old Jul 26, 2009 | 06:56 PM
jsbayer's Avatar
Well i just found the BOV that is on my car, here at http://www.360infiniteusa.com/sbv-bl...val-p-241.html
Thinking it was prolly not acting right, if the thing is only $15.99...jeez...But to me, i would think it should be air tight at idle, or all the way til letting off throttle and needing to then open? Am i thinking wrong?
Old Jul 26, 2009 | 07:04 PM
slow96lude's Avatar
You have to remember that vacuum from your intake is pullin the BOV open as it would be once you let off the gas to shift and blow off. Once you start making boost it shuts the BOV and the spring inside helps with that operation to. But it should not be blowin air out of the BOV it should be suckin it in. Not sure if it just feels like it to you
Old Jul 26, 2009 | 07:05 PM
jsbayer's Avatar
Its too late to go start it up, lol...ill double check what feeling it is tomorow morning...but that makes sense...didnt take that into account...appreciate the help!
Old Jul 26, 2009 | 08:03 PM
srmofo's Avatar
that kinda depends sometimes turbos will spool and creat a little boost at idle, which is why the bov is venting....this seems to be a little more common on the BB turbos
Old Jul 27, 2009 | 04:40 AM
dpetro1's Avatar
https://honda-tech.com/forums/forced-induction-16/new-tial-wastegate-plumbing-2608121/
start at post #12 and read what tial has to say about the bov being open
Old Jul 27, 2009 | 04:55 AM
jsbayer's Avatar
Wow...that is a good laugh, thanks for the link though...clear as day!
Old Jul 27, 2009 | 06:29 PM
slow96lude's Avatar
that is true tho about the map sensor being before or after the bov. I have no idea at all where the Map would be pre BOV but I see where he is coming from.
KevinEF7
Jan 24, 2013 02:31 PM
DelSeeYa
Oct 7, 2009 11:07 AM
welfarepc
Aug 19, 2007 08:26 PM
LostCRX
Apr 20, 2004 04:35 PM
SLIMJIMsi97
Jun 18, 2003 04:40 AM
