urgent: eagle rod fitiment issue
Old Aug 23, 2002 | 03:30 PM
tygsr's Avatar
Default urgent: eagle rod fitiment issue
has anyone had problems with the eagle rods in their gsr? the shop just called me saying the bearings dont fit right with these rods and that they wont put it together wrong,etc,etc..anyone have this problem and if so if there a quick solution? the last thing I want to do is have my car down another 3 weeks...any help would be great.....
Old Aug 23, 2002 | 03:41 PM
DRAGLS's Avatar
Default Re: urgent: eagle rod fitiment issue (tygsr)
What bearings are you using? I had my machine shop take the measurements and special order them it ended up being Federal mogul bearings.
Old Aug 23, 2002 | 04:11 PM
GruvyTune's Avatar
New User
std acl bearing fit just fine.
Old Aug 23, 2002 | 04:26 PM
tygsr's Avatar
Default Re: urgent: eagle rod fitiment issue (GruvyTune)
they are trying to use oem bearings, is this the problem??
Old Aug 23, 2002 | 07:27 PM
Ltech's Avatar
use ACL bearings.
Old Aug 23, 2002 | 08:07 PM
ekb18c's Avatar
Default Re: urgent: eagle rod fitiment issue (Ltech)
ACL or OEM bearings should be fine. Unless they're oversized bearings.
Old Aug 24, 2002 | 10:17 AM
tygsr's Avatar
Default Re: urgent: eagle rod fitiment issue (ekb18c)
apparently the problem was in the way they were built..on the rod where the bearing is held in place the pin or bolt or whatever it is was cut on the inside rather than the outside so the bearing wont fit, honda oem or aftermarket so I haft to get eagle to overnight me a new set of rods...pain in the ***!!
Old Aug 24, 2002 | 10:36 AM
Kamin's Avatar
are they doing it for free?
Old Aug 24, 2002 | 12:58 PM
ninesecrx's Avatar
Default Re: urgent: eagle rod fitiment issue (KAMiN)
I dont mean to sound negative, but you know when everyone says of yeah, save your money and get eagles. Theres no difference from them or crowers. Well theres an example. A rod that is made over seas with less quality control. I mean...so they made a bunk rod, well what happened to the quality control people making sure every rod is in spec? Thats why id stick to a crower vs a eagle...you would have your motor together by now.....Mike
Old Aug 24, 2002 | 04:40 PM
philo's Avatar
I had a similar problem so I sent them back and went crower (thanks ben). Holding both sets side by side you can see why the crowers are twice the price. I am happy they did not fit as I like the crowers a lot better.
Old Aug 24, 2002 | 09:51 PM
dvp95's Avatar
Default Re: urgent: eagle rod fitiment issue (philo)
Is this fitment issue with all series engines? I have the eagle rods for my h22 but isnt installed yet. Which bearings should I use (stock?)?
Old Aug 25, 2002 | 05:45 AM
bigTom's Avatar
Default Re: urgent: eagle rod fitiment issue (ninesecrx)
like i always like to say... u get what u pay for... yet many people still dont believe me
Luded93
Apr 4, 2011 01:29 PM
Fc_v8
Apr 1, 2010 11:20 PM
itralex
Sep 11, 2004 03:16 AM
reditr
Jan 17, 2004 12:39 PM
EKweezy
Oct 8, 2003 10:09 AM
