Where on the oil pan do I get my fitting welded?
Re: Where on the oil pan do I get my fitting welded? (On Point EK!!!!!!!!)
It needs to be up high, higher than the oil line would be when the pan is full.
Rob
Rob
Re: Where on the oil pan do I get my fitting welded? (rjardy)
as close to the top of the oil pan as u can get it to be... if u put it lower the oil will back into the line and therefore the line will become backed up
Re: Where on the oil pan do I get my fitting welded? (ek9t)
There is a little tip about placing it across from a crank main. As in, don't mount it so that the crank itself is swinging directly in front of it, as this could cause turbulence, thus hindering oil return.
This was brought to you from Honda Builder's Handbook, Vol I.
Re: Where on the oil pan do I get my fitting welded? (EGb18cT)
I loosely attached my downpipe to the turbine side when marking my oil pan. It's hard to be sure of a good placement without doing this. The advice to tap up high is good, as we all know gravity is doing most of the work in the return line. Here are some excellent, up-close pics courtesy of Dustin's site:
http://imglib.************/index.cgi?cmd=viewimage&id=32
http://imglib.************/index.cgi?cmd=viewimage&id=33
toolowsol
02-09-2006 01:52 PM
