how do u do a Compression Test ??
Theres a tube connected to a gauge, and the other end, had a fitting with threads, that goes into the spark plug hole. take out the ecu fuse and crank, and check the what the gauge reads. Have a friend there, you cant do this by yourself.
http://www.superhonda.com/forum/f55/...n-test-124194/
for more accurate results make sure the engine is near operating temperature while performing the test.
