"Super 60" for stock LS....300whp?
I am building a LS-T for my EG hatch. I have been looking at a T3 Super 60 for a fast spooling street turbo. My goal is around 300whp but high 200's would be fine. I plan to run a full 3" turbo back exhaust.
My plan is to keep the engine bone stock except a Skunk2 IM, this way when it blows I can simply swap it out with ease. Given my power goals, its easier to swap then build one.
My question is: Will a Super 60 do it on pump or should I go with the usual T3/T04E setup?
I am purchasing everything from Spoolin Performance.
Thanks all...
Thanks all...
Thanks all...
Thanks all...
if want to keep your AC i would go with the t3t3, because its a little smaller and could be easy the work around the ac componets
you could rock a .48 a/r t3/to4e 57 trim and have good spool and 300whp capability. hell the .63 a/r housing probably wouldnt spool that much later but yeah.
i ran the .48 ar 57 trim on a stock ls motor like 2 years ago. i totally loved it. 10 psi at about 3800(which is low enough trust me) and it pulled sweet to 7500 redline. it was an awesome setup. the same turbo on a different ls motor made 241/210 on 10 psi. it was a stock map sensor/dsm 450s/uberdata chip setup and it rocked.
Lawbags
Oct 6, 2017 05:15 AM
