Suspension & Brakes Theory, alignment, spring rates....
Can't bleed brakes
Old Jul 23, 2009 | 04:39 AM
morepowerjoe's Avatar
Default Can't bleed brakes
I have a 93 EX Accord (ABS). The master cylinder ran dry and I blead it, the abs, and all four corners. No matter how I do it, all the calipers just keep pumping a lot of air out. Thanks for any help.
Old Jul 24, 2009 | 03:53 AM
Default Re: Can't bleed brakes
oh well, I just ripped all the abs crap off and put a prop valve where the abs used to be. Brakes are perfect now.
Old Jul 26, 2009 | 07:07 PM
chewibui's Avatar
check all abs hard lines, look for cracks and leaks
Old Jul 27, 2009 | 04:28 PM
JonMaltese/LScivic's Avatar
i would look at why the master ran dry... all four corners always have air??
Old Jul 28, 2009 | 10:03 AM
mistajdm's Avatar
check for leaks, if not keep bleeding until you get all the air out.
lak8
May 2, 2008 02:40 PM
richcon
Jun 10, 2007 07:50 AM
The-Kid
Aug 24, 2006 09:19 AM
jonzel
Aug 18, 2005 04:47 PM
joeseph
May 23, 2003 10:13 AM
