Please Help!!!! ABS PROBLEMS
Old Jun 6, 2007 | 09:30 PM
richcon's Avatar
Default Please Help!!!! ABS PROBLEMS
Hey guys I need help!
I just changed my master cylinder in my 94 Integra GSR due to it leaking in too the booster and the ABS light was turned on and the ABS pump was priming constantly.
I changed it , bled the brakes thinking it would fix the problem.
Well it was fine for the first 5 min and then the brakes locked up and now the car will not move.
What do you think it is??
ABS control Mod, ABS Pump??
Note: Master Cylinder is fine.
Old Jun 7, 2007 | 05:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The ABS and brake MC are 2 separate things on 94-97 Integras. Why did you bother with the MC if you were having a problem with the ABS?
You'll probably have to try to find a used ABS pump from a junk yard or something, either that or pull the fuse and disable ABS altogether.
Old Jun 7, 2007 | 05:47 AM
richcon's Avatar
No the master cylinder was leaking
so yes it needed changed
And the ABS primes we are just trying to figure out why the brakes locked up "car wont move"
Old Jun 7, 2007 | 11:05 AM
richcon's Avatar
We bled the brakes and after each time we did that aprox. 5 min after driving they slowly locked up
Old Jun 7, 2007 | 11:12 AM
Community Builder
that's weird. Is the ABS throwing any codes?
Old Jun 7, 2007 | 11:15 AM
frstbte14's Avatar
Default Re: (PatrickGSR94)
I know it's this way for jeeps, but as far as the ABS system goes, there is a special way you have to bleed them. I'll check my manual
Old Jun 7, 2007 | 12:34 PM
richcon's Avatar
Yes the light is on and goes off
but there are no codes being thrown
im stumped
btw thanks for all of your help guys
please let me know if you have any options
Old Jun 10, 2007 | 05:53 AM
Legal Bill's Avatar
Default FWIW
Ok, I am total noob to this site and to Acuras and Integras. I was doing a search for my own ABS issue before I started a thread and found this one. FWIW, the problem you describe was very common to old british sports cars, and there were a couple of possible problems.
1. A brake line was clogged (usually a rubber line) and would not allow brake fluid prssure to pass back into the M/C after you released the brakes. This was usually gradual and would lock up after a few minutes. Are all 4 brakes locking, or just one end?
2. Power booster (I'm not even sure an Integra has one...) would actuate and "push" the fluid, but then not return. Easiest test was to by-pass the booster and see what happens.
Old Jun 10, 2007 | 07:50 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Please Help!!!! ABS PROBLEMS (richcon)
Pull the ABS codes the same way that you would a CEL (just read the ABS light). The result can guide the diagnosis. I personally think that there is a problem with the MC as the ABS should not be able to lock the brakes. The fail-safe relay on the ABS should prevent against such occurrences.
Chim Chim
Mar 31, 2007 07:36 AM
highcomp
Apr 15, 2004 07:36 PM
DI9ITAL
Jan 26, 2003 10:42 AM
olddriver
May 1, 2002 07:16 AM
