idle drops when radiator fan kicks on?
Old Jul 18, 2009 | 08:30 AM
autoponicz's Avatar
Default idle drops when radiator fan kicks on?
hi all....
im getting my car back on the road after being a 2 year gararge queen..(i still start her up every week or 2)
i have a 96 hatch with a jdm b16, jumper harness to run the jdm b16 ecu.
motor is fine..pulls hard and starts up with no problems..
so recently when i come to a light or sitting parked...the idle would drop when the rad. fan kicks on or when i use the wipers or cabin blower..
idle will drop then surge a few times..by then i would blip the throttle and then idle goes back to the normal ...
if i dont turn anything else on (blower/wipers/lights) ...idle will just drop when the rad. fan kicks on..
but lets say if i have the wipers on also....the idle will SURGE...
...and if i blip the throttle...idle goes back to normal..
where can i check for something like this...
gonna check the voltage on the battery and alternator tomorrow...
double check the grounds..
anywhere else i should look at.?
or have an idea why its doing that,/.?
Old Jul 18, 2009 | 08:43 AM
90Rexx's Avatar
Default Re: idle drops when radiator fan kicks on?
clean your IACV....
Old Jul 18, 2009 | 08:52 AM
autoponicz's Avatar
i cleaned it a while back...guess ill take a look at it again...
Old May 5, 2018 | 01:24 PM
BigRed34's Avatar
I'm having the same problem but it's also when I would my windows up aswell when I'm idling. Did find a solution for the issue?
Old May 5, 2018 | 01:25 PM
BigRed34's Avatar
Originally Posted by BigRed34
I'm having the same problem but it's also when I would put my windows up aswell when I'm idling. Did find a solution for the issue?
Old May 5, 2018 | 05:25 PM
tony_2018's Avatar
Fish Twig
2ndchirp
Oct 13, 2022 10:21 AM
dth0ng69
Apr 12, 2010 04:13 AM
the.hamburglar
Apr 22, 2007 11:20 AM
jakscivic
Feb 24, 2006 07:22 AM
slamdunkcivic
Jan 19, 2005 11:06 AM
