really weird idle problem with lsvtec
Old Feb 23, 2006 | 01:20 PM
jakscivic's Avatar
Default really weird idle problem with lsvtec
Ok so i got everything sorted out and plugged in. I start the car and it has a super high idle. I tried the finger over the iacv hole and the idle doesnt drop. So i waited until my fan turned on to check it again because thats what the book suggests. So the fan turned on and about 7 seconds ofter the fan turned on the idle dropped to about 1500 and it sounded like a shitty idle. Then it dropped to about 500 or so and it was like a domestic camming out. It was like duh duh duh duh duh. it sounded bad. So i tried to push on the gas and it had no responce what so ever. And i know the throttle has responce because i have reved it up before. So the idle eventually went back to 2500 then dropped to 500 again. What the hell is going on with this? thanks for any suggestions
Old Feb 23, 2006 | 03:37 PM
jakscivic's Avatar
Default Re: really weird idle problem with lsvtec (jakscivic)
i actually did clean the iacv to just make sure it wasnt that and it ended up being part of the problem but not the solution. It still idles like a domestic and it smells like gas really bad. Its weird cuz when it idled really high at 2500 the throttle would respond fine. But now that its down to about 1500 the throttle takes a second to respond and its not smooth going up, it goes up really fast then it lower than 1500 then shoots back up to 1500. Could this be timing? I tried to advance and retard the timing with little progress. Please help
Old Feb 23, 2006 | 04:16 PM
jakscivic's Avatar
bump
Old Feb 23, 2006 | 06:04 PM
jakscivic's Avatar
no one? come on please. If no one knows then just say take it to a shop or something.
Old Feb 23, 2006 | 06:15 PM
amckee's Avatar
Default Re: (jakscivic)
In a situation like this I would start with making sure the base idle was correct. Unplug the IACV and see if you can set the idle to between 450 and 500. Plug it back in and clear the code. I would also check things that would keep the ECU in default and running rich such as the ECT sensor. If the engine is warm and your idle is 1500 and above without surging, then I would suspect the ECU is in default. Check for 5 volts to the ECT sensor with key on engine off. Warm resistance should be around 300 ohms.
Old Feb 23, 2006 | 06:35 PM
jakscivic's Avatar
well i had the head in my car before and it ran fine, idle was fine and everything. Although i cleaned the iacv and it was fine before i just dont see why the idle would be off by that much. I was thinking something ignition wise, or maybe timing, but i would have to be off by quite a few teeth for it to sound like that i think. Oh and what is the ECT sensor, im not familiar with that. And what do you mean by surging?
Old Feb 23, 2006 | 06:55 PM
sickerhatch's Avatar
Are the timeing marks all lined up?
Old Feb 23, 2006 | 06:59 PM
jakscivic's Avatar
last time i checked it was lined up. the only thing im not completly sure about is the crank line. Im not 100% sure that is all lined up. but the cams have been lined up. Is there a way to check the crank line with out taking off the crank pully?
Old Feb 23, 2006 | 07:12 PM
jakscivic's Avatar
oh, and if the head gasket was on upside down would that effect how it runs? ive heard that it will leak major oil if it is, but i have a feeling that it is. It has a little bit of the gasket sticking out the side of the engine, which doesnt look right. Would this help or am i wrong?
Old Feb 23, 2006 | 07:19 PM
just line the white mark on the crank pully up with the pointer on the lower timeing belt cover then the crank is at tdc.
Old Feb 23, 2006 | 07:27 PM
jakscivic's Avatar
ooooooooh ****, i didnt know about those marks. i will try and check that tomorrow. thanks for the info so far. Any other ideas?
Old Feb 24, 2006 | 07:22 AM
jakscivic's Avatar
ashe
Aug 4, 2003 07:39 AM
tylerdurden
Apr 11, 2003 05:53 PM
chirp2hrd
Oct 13, 2002 01:36 AM
3s-gte
Aug 22, 2001 12:41 PM
