fluctuating idle when hot.
The idle in my B16 is fine 99% of the time, I have noticed that if I get stuck in traffic or a drive thru etc and the motor gets a bit warm, not even enough for the fan to cut in but warmer than normal driving, the idle starts to go up to just over 1K and back again in a rythum, as it gets hotter (longer in traffic) it gets worse and has gone up to 2.2K and down again before, still to a beat.
Soon as I start driving and it cools to normal running temp its fine.
The coolent is bled and full and has been untouched for about a year and this has only just started.
I searched but nothing seemed like my problem, all the results seemed to be at cold or all the time. So sorry in advance.
Re: fluctuating idle when hot. (slamdunkcivic)
under the throttle body if you have an obd1 throttle body. how's your cooling system doing? any CEL's? i had a similar problem when my coolant temp sensor wiring was bad.
.:::I'm Fantastic:::.
04-17-2010 12:32 PM
