Car spitting, surging and sputtering
Old Jul 17, 2009 | 08:10 AM
theczechone's Avatar
Default Car spitting, surging and sputtering
I have a 92 vx hatch with a 2nd gen jdm b16a, other than that pretty much stock.
My car has got some issues.
Symptoms:
- Car spitting and sputtering, jerking to where its undriveable
- Surges at idle, but stops after a while.
- No Ecu codes
Notes:
- In the morning after the car has set up all night the car cranks right up and drives fine, however if I stop turn the car off and take back off it starts acting up again.
- Problem first showed up when its got hot and humid down here (about 95F and 100% humidity)
- During early afternoon it is the worst
- If I floor the gas pedal the car picks up and revs well in high rpm as soon as I come off of it the car spitts and sputters and the tach needle jumps or goes to 0 rpm while the car sounds like it runs on 1 or 2 cylinders.
- If I turn on the A/C or any other kind of accessory that draws power from the battery the car runs fine for a while it starts messing up again and I can turn on additional accesories to make it run better for a while longer.
- If I pull the green plug out of the alternator the car goes from rough idle to smooth idle.
Checked things
- replaced the alternator - thought the voltage regulator was bad
- replaced the ecu - running a P30
- checked the MAP sensor - used one of a good running car and ran mine on the good running car
- replaced spark plugs (NGK irridium), plug wires (Duralast), Cap and rotor
- checked the Ignition Control Module -followed haynes manual
- checked the Ignition Coil -followed haynes manual
Please Help
I think it has to do something with the charging system...
Old Jul 17, 2009 | 12:13 PM
Default Re: Car spitting, surging and sputtering
bump! bored at work
Old Jul 17, 2009 | 04:34 PM
424racer's Avatar
try changing the dizzy.
i had that kind of problem and i changed the dizzy...
BUMP IT UP AND HLEP HIM OUT.......
Old Jul 17, 2009 | 05:58 PM
thanks man, and I will borrow my buddies distributor tomorrow,
he has an LS integra, the dizzy is the same right?
Old Jul 17, 2009 | 07:56 PM
424racer's Avatar
no there not... it wont work unles you remove one of the legs.
you will need a dohc vtec dizzy...
Old Jul 17, 2009 | 08:17 PM
LS is a dohc b18b2 motor
Old Jul 18, 2009 | 07:45 AM
but you were right the distributors do not match,
i don't know anyone else willing to lend a dizzy what can i do, I really need some help guys!
Old Jul 19, 2009 | 06:27 AM
I really need help with this guys, please give me some input
Old Jul 19, 2009 | 06:44 AM
fcm's Avatar
fcm
Old Fart
I have to agree, and it is what I would try next, try another distributor. 94
B18cHatch06
Feb 23, 2006 11:36 AM
B_1_8_hatch
Mar 15, 2004 06:09 PM
B_1_8_hatch
Mar 14, 2004 12:36 PM
RS1995
Jun 8, 2002 08:17 PM
dirtySOHC's
12
Feb 21, 2002 07:21 PM
