EM1? WOULD AN ALTERNATOR BURN THE ECU???? WIERD!
Old Jul 12, 2009 | 12:53 PM
rjmancia's Avatar
Default EM1? WOULD AN ALTERNATOR BURN THE ECU???? WIERD!
well first off... i have a 2000 Em1. It has a built JDM B16A. My first ECU was a SI-R jdm ECU with a JUN SPEC chip... my CEL came on about once a month... it would come one very rarely but noticed that it only came on especially when it was hot outside and when i am about to go to a stop and you let go of the gas and rpms come down... right when it hits 2,500 rpms it comes on and then i stay idled at 1,000 instead of normal 750... (which i believe they call that loop mode...) well i turned the car off, turned it back on and CEL wasnt there no more. It then started doing it constantly after a while and my car would bog like crazy... like if it was wanting to cut fuel and or turn off. After that i went to one of the local private tuner guys and he told me that the ECU was probably bad sooo he gave me another JDM ecu (it is stock or virgin i should say) it has been running fine... i have been driving on it for about 1 month now... but yesterday it did the whole CEL turning on again at about 2,500 RPMS.... WTF!!! LOL i turned the car off and back on and no CEL and hasnt came on since... but i really dont wanna mess this one up as well.... any help??? The guy told me that the Alternator was burning my ECU up... which i dont understand... he was saying something about the ELD??? i am using the OBD2 harness but have a jump harness to my OBD1 ECU.... any suggestions??? also my lights get brighter when i let go of the gas or turn on my signals to turn lol!! i dont know.... but please help before this one goes bad thanks!!!
Old Jul 12, 2009 | 01:05 PM
Former User's Avatar
Default Re: EM1? WOULD AN ALTERNATOR BURN THE ECU???? WIERD!
If the CEL turns ON, then pull the codes. You may get valuable information. It's unclear at this point that your ECU is bad.
Dimming and brightening of the lights suggests that the alternator needs to be replaced.
Old Jul 12, 2009 | 01:32 PM
rjmancia's Avatar
okay... cool bro thanks for the info... that is what i have been told many times... soo im pretty damn sure i will be replacing the alternator....
Old Jul 12, 2009 | 09:49 PM
rjmancia's Avatar
bump.... also can i check the CEL code on an OBD1 while the car is on?
Old Jul 13, 2009 | 06:18 AM
Yes
Old Jul 13, 2009 | 03:52 PM
r berq's Avatar
Alternator has a voltage regulator built in. If the regulator goes bad it can send too much voltage, make the lights extra bright, and start burning stuff up or blowing fuses.
Old Jul 15, 2009 | 04:18 PM
rjmancia's Avatar
woah!!! i think you are right... well time to change that **** before it starts burning stuff up man...
Old Jul 15, 2009 | 04:19 PM
rjmancia's Avatar
would it make the lights dimmer and brighter though???
Old Jul 15, 2009 | 04:45 PM
ek9=]'s Avatar
yeah thats your alternator, change that **** nowww
Old Jul 15, 2009 | 11:06 PM
rjmancia's Avatar
hmmm... well i should but i went to Autozone and O'rieleys to get it checked and showed that it was running at 13.8 Vlts and the battery was good as well... the thing is that... k lets say im driving... at night.. the lights are on and im driving about 40mph. I dont push the clutch but let go of gas pedal everything turns brighter but once i press on the gas... it gets dimmer again... same if i press on clutch it gets brighter for split second then back to dimm again... WTF!!! lol!! i hope it doesnt burn my ECU up... i have a OBD2 Harness with a Skunk2 OBD1 Jump harness to a OBD1 SI-R ECU... let me know what you think guys... also wat kinda alternator should i use??
Old Jul 16, 2009 | 07:29 AM
rjmancia's Avatar
cmon peeps... need your help
Old Jul 16, 2009 | 07:48 AM
Utzz's Avatar
So you're not getting a CEL anymore?
Old Jul 16, 2009 | 07:19 PM
rjmancia's Avatar
it does it really random... but if i turn the car off when it does come on... the light turns off and doesnt come on again for a while...
skyliner34life
Engine Management and Tuning
Jul 5, 2016 06:05 AM
ramboPandA
Apr 5, 2015 06:20 PM
tianporn
Jul 31, 2014 08:34 PM
k20user
Jul 12, 2012 12:08 AM
LoseRPunKx182
Dec 25, 2005 09:09 PM
