I'm confused, please show me what oil pan I need!
Old Jul 6, 2009 | 02:58 PM
longskate87's Avatar
Default I'm confused, please show me what oil pan I need!
So I've decided to replace the oil pan in my 96 EX Civic Coupe. The engine block says D16Y8, it is an auto tranny, What oil pan do I need? There are two styles I've seen, and I keep reading contradictory info on which one will fit. Examples of the two are listed below. Please help me pick one! Thanks!
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
http://cgi.ebay.com/ebaymotors/96-00...Q5fAccessories
Old Jul 6, 2009 | 03:09 PM
redline7070's Avatar
Default Re: I'm confused, please show me what oil pan I need!
Old Jul 6, 2009 | 05:26 PM
94EG8's Avatar
Seagull Management
Originally Posted by redline7070
Correct
Y8's use an oddball aluminum oil pan. The add says Si because the EX coupe is called an Si in Canada in case anyone wondered.
Old Jul 6, 2009 | 06:57 PM
mattliston's Avatar
both pans from the auctions fit the motor, the question is will it allow proper clearance for the exhaust?
Id buy the black one
Old Jul 6, 2009 | 07:00 PM
98civdx's Avatar
Master Detailer
its # 2
^^^as94EG8 said y8s use a weird pan, not like the y7.
Old Jul 6, 2009 | 07:19 PM
mattliston's Avatar
I just compared each to the dealership pictures,. seems the Y7 oil pan is teh weird one, which makes sense because the exhaust manifold has the catalytic converter directly bolt onto it
so again, buy the black one.
Old Jul 6, 2009 | 07:26 PM
94EG8's Avatar
Seagull Management
I seem to recall their being an oil pan gasket issue with trying to run a Y7 oil pan on a Y8 or vice versa, IIRC it centered around the Y8 using kind of a weird gasket compared to everything else.
Old Jul 6, 2009 | 07:42 PM
MHDesigns's Avatar
Just out of random curiosity. Why are you changing the pan?
Old Jul 6, 2009 | 11:18 PM
Long story, but it needs to be changed, bolt is FUBAR.
So half are saying get the black one, half are saying get #2...Can anyone say fror sure? The sure look different to me.
Old Jul 7, 2009 | 02:41 AM
94EG8's Avatar
Seagull Management
Yes, the aluminum pan is the one to get, 100% gaurenteed to fit.
Old Jul 7, 2009 | 08:09 AM
xunsungheroesx's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-civic-oil-pans-2423414/
Old Jul 7, 2009 | 10:08 AM
mattliston's Avatar
well I just confirmed that a d16y7 oil pan has a BOLT on baffle inside, so look for that i guesss. oil pan gaskets are pan specific as well
I havent confirmed which is which though just from looking at the outside
aavtec
Honda Civic (2006 - 2015)
Apr 21, 2016 11:41 PM
Ls1 FD3s
Apr 3, 2005 03:19 PM
RE-Spect
Jul 23, 2003 12:33 AM
