gsr obd1 question
hey guys i have a question i just wanna double check on something.
i put a gsr motor (obd1) into my civic. im using the old d16y7 obd2 wiring harness on in.
my question is... will i run into any problems if i use obd2 to obd1 jumper harness and a p28?
ive heard yes and no from many people i just wanted to see if anyone knew for sure.
thanks guys.
thanks guys.
i used an obd2a to obd1 jumper harness. and yeah the iacv is giving me problems. i also had to extend some plugs. when i give it gas it revs up just a little then it cuts off.
This is a good link for the 3wire-2wire conversion
http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
right, obd1 is in the dizzy. we still did that trick and have obd1 to 2 conversion and switch the tps wires runs better but still feels like hes towing a trailer at 5k rpm and it seems maxed out and loud. and cel is on for manufacture igintion misfire....? any suggestions
What code is on? Two wire switch on the TPS? why
yeah thats what i meant. original motor was a y7 with the TB that faces up and the butterfly opens backwards. dude put a gsr motr in. the engine thinks its wot when its shut. we switched it and it runs alot smoother but still feels like towing a train and maxes out at 5k rpm. il have him ina few minutes post the codes
alright so i got a few more codes from the last time we had it checked.
p1382 misfire/ignition
p0500 speed sensor
p0135 o2
p0141 o2
im gonna change the tb tomorrow morning see if the difference in tps sensors.
p0500 speed sensor
p0135 o2
p0141 o2
bobjohnson
May 1, 2008 07:38 PM
2wheelhunter
Jun 4, 2007 04:18 PM
